Type E crossovers in a La Scala?
nomar247
I am in the process of rebuilding my Type A crossovers from Crites.
In the meantime, would it be possible to use a spare Type E crossovers in a pair of La Scalas?
Using the type E in a Lascala would give you lots of bass and very little midrange or highs.
Bob Crites
Curious
Just curious as to why they would not work. Is it the crossover frequencys (700/6000) or a mis-match of driver impedances throwing off the crossover points? Maybe both?:scratch2:
The crossover frequency would be wrong because it is at 400hz for the Lascala and 700hz for the Heresy. But that is not the main problem. The sensitivity of the Lascala bass bin is about 104db at 1 watt. The sensitivity of the bass in the Heresy is 96db at one watt. So, in the Heresy the midrange and tweeter have to be attenuated to match the bass output. That attenuation happens in the crossover, so, if you use the Heresy type E crossover in the Lascala, you will have the bass at 104db/1 watt and the midrange and tweeter attenuated to 96db/1 watt. So you will get lots of bass and very little of the other frequencies.
Bob Crites
correct me if wrong- - but don't E and A share the same inductor and autoformer? - assuming so you can convert the E into an A by a cap and autoformer tap change (you could parallel a 10->11uF with the first 2uF)
