I use 6L tank and 4 at a time. Would I like to do more. Yes, but the price value time proposition wasn't in my favor so I opted to go down this path initially. So far my unit continues to operate as it should. I f I need to replace it down the road I won't feel bad because I didn't pay much for it to start with. The Vinyl Stack Ultra has been great and is a well made and optioned unit.
I guess they moved to three to provide more space between LP's. Not a good move and I would not want to move in that direction. If I ever find myself replacing what I currently have I will look at what 4-2-7 has and move up to the 8-pak.
Hi folks, haven't posted before but have lurked for a while. Thought I could add a bit from my research. As Bob06 replied, VinylStack made a decision based on feedback from members of the diyAudio forum that the record spacing should be wider than their original 4-record spindle allowed. The goal is to have records spaced 1" apart for more effective ultrasonic cleaning. So, they modified their spindle to accommodate this resulting in a 3-record stack for a 6L tank. As noted before, they also offer an optional 4-record spindle if you have a larger tank (e.g., 10L).I don`t know why they went to 3. I wonder if they felt the magnet was marginal for 4 ?? Seems plenty strong for 3...
Exactly correct. It was a conscious decision by VinylStack to create more space between LPs because that's what many of their users were requesting. For me, and based on my research, this is a very good change. I've tried 8-record spindles in a 10L tank using the Ultrasonic V-8 setup, and it sure it faster to clean 8 at a time. But I've chosen to go with wider spacing.I guess they moved to three to provide more space between LP's. Not a good move and I would not want to move in that direction. If I ever find myself replacing what I currently have I will look at what 4-2-7 has and move up to the 8-pak.
Cyto, if you're interested in a 10L tank for only a little more than many of the 6L tanks, the Trusonik 10L tanks seem well build and reliable. Here's a listing for the Trusonik 10L from one of their distributors as of August 2016 at $199.95:Would mind sharing what brand your 6L tank is and possibly where you got it?
And now I know why you call yourself Smart Ass, 4-2-7. But, I encourage folks thinking of using less than 1" spacing to do their own research on the issue. Might even be worth actually doing some controlled testing to see what the results you get.And that's really only a groupthink opinion based on nothing really over at DYI.
Reliable? and cheap, I already burnt one of these out, but had gotten 1600 records cleaned with it. I did buy another one and it's lasting longer, well I should say I'v cleaned more records with it.if you're interested in a 10L tank for only a little more than many of the 6L tanks, the Trusonik 10L tanks seem well build and reliable.
Wildcat, I agree about the value of the VPI thread on ultrasonic cleaning. Harry Weisfeld started as a skeptic, observed some negative results in the high frequencies, continued to experiment to resolve the negative issues, and is now wholeheartedly enthusiastic about the results he's getting. Like you, I'm largely following the same setup he's currently using but playing around with what I'm using in the ultrasonic bath (Tertigol rather than Photo-flo, for example) and with filtering the water. I pay attention to HW's comments because he's always willing to actually try something to see if he can get better results.I have the 3-LP Vinyl Stack, and three at a time is enough for me to handle. Thing is, I do a rinse with filtered water on a record vac after doing the ultrasonic, as that rinses the last of the crud off. So I can do about 15-18 per hour. I get the water warm but not hot, and have no warpage issues.
Check out Harry Weisfeld's thread on VPI's forum, and that is exactly the method he uses (although he uses a second Vinyl Stack). He has tried different methods and has compared the results. Interesting reading!
http://vpiindustries.com/forum/viewtopic.php?f=9&t=2289
For me, personally, nothing I've tried has worked as well as ultrasonic cleaning, followed by the vacuum cycle. I have some new 180g records that come out almost completely silent in terms of background noise. Nice!
