Are you moving on getting a system together?great info...
Oh I have bought one and have cleaned close to 100 of LPs (see my first post here). Mine has no heating function though.Are you moving on getting a system together?
Forgot to ask: Do you use any cleaning fluid? The manufacturer of the unit I bought advised that clean/distill water works best.The record should be spinning very slow, so no water drips down onto the label and a seal is not needed. What little water that is on the record as it rolls just drains down the grooves.
People have setup manual spinning devices but it has to be rotated. However if you go manual you have to stay there and do it for the whole time the records are in the tank. If it's motorized you drop the records in and go do other things like clean up the covers, listen to music instead of the machine. Not having to have hands on the whole time is a big plus for a cleaning method.
I also don't vacuum them dry, I put them in dry racks. Once dry I do a quick wipe with a old school flannel lint rag and put them in new sleeves. One thing about a heated tank, it expands the vinyl and the records will look puckered, and warped at this point. Once out of the tank and cooled they contract and go back to normal. This expansion and contraction acts as a stress relief pulling all static out of the record.
Static on a record is from friction that the stylus dragging though the grooves dose as well as pulling it in and out of the sleeve. Just like rubbing your rubber shoes on carpet, or rubbing a ballon in your hair. A vacuum device has friction and adds static back onto the record that you just removed.
Also when we buy used records the ones we find that look mint and perfect like they where new, where not played or handled much by a past owner. The more a human handles a record the more chances of damage, rubbing and scrubbing a record surface is not the best thing. We can also drop them, or drop a bush or scratch them in handling.
The top of my list as the best things about cleaning with a heated US cleaning tank.
Less hands on that frees your time for other things and not listening to the machine
No physical rubbing on the surface of the record.
Expansion and contraction that removes static.
In my 2 gal/ 10L tank I add about 4-5 oz 90% ISP alcohol a couple drops dish soap and a drop or two of photo-flow. With the agitation of ultrasonics you don't need many or much solvents to do the job. Hear again I'm a less is more guy and not wanting to subject the surface of a record to more than is needed.Forgot to ask: Do you use any cleaning fluid? The manufacturer of the unit I bought advised that clean/distill water works best.
Has a lot to do with what you are using in your cleaning fluid.I can also attest that ultrasonic cleaning significantly reduces static. Exactly how I don't know.
jesus.Let me also let everyone in on a secret secondary use of the US Cleaner!
I have a 6 year old daughter who does number twos like an 18 year old bloke. Not only that but she fills the bowl with toilet paper too.
Needless to say my bottom toilet has been off limits until I can get a plumber round.
I’ve put drain cleaner down it (the unblocked stuff), a whole bottle and it didn’t do a thing.
Today I dumped my cleaning fluid down the toilet as it was looking a little dirty. 80% distilled water, 20% IPA and 1% Kodak Photoflo.
Lo and behold the toilet now flushed perfectly. Very odd!!!! But a welcome relief to have another toilet back up and running.
I will need the complete vinyl cleaning apparatus as well. there are a few on aliexpress 150 to 200 usdThere are cheaper and more expensive models. Research 15 liter ultrasonic tanks on ebay and you will find very affordable units.
Below is the unit I use. Highly recommend it. Super solid operation. Easy setup and cleanup. Just place the tank to the platform and your ready to go. Nothing to build once the tank is added. eBay seller is tws. No affiliation other than as a satisfied customer.
.Below is the unit I use. Highly recommend it. Super solid operation. Easy setup and cleanup. Just place the tank to the platform and your ready to go. Nothing to build once the tank is added. eBay seller is tws. No affiliation other than as a satisfied customer.
