Hey folks,
I just aquaried this little SE el84 stereo amp. It is quite a simple looking amp. The tubes in it are RCA manufactured for ultratone. The driver is a 6eu7. It takes a 6ca4 rectifier.
I have done a fair amount of googling and have not found the schematic.
Something interesting to me, the output transformers have different taps than I am used to seeing. There are 4 primary taps. One is b+, one connects to pin 7 of the el84. On the other two, one connects to the el84 after it goes through a resistor, and the last tap goes through a resistor and then connects to the 6eu7.
That make sense? ANyone seen a schematic like this? Anyone understand what is happening here?
Looks alot like your amp except the power transformer since they're separate. They were tossed to the garbage at my work. Each use one 6x4 rectifier, one 6av6, and one EL84 (one amp have what is made in Holland and other amp have what is made in Britain). They sound pretty good through my headphones along with the loading resistors.
