Okay folks,
I went to town on this little amp. I do have a question.
There is a 100uf 15v non-polarized cap under the hood. It connects from both of pin 3's on the 6bq5's to ground. I didn't realize I didn't have this cap - bummer. I do have a 100uf 100v polarized cap though.
Can I sub this cap in as long as I put the negative side to ground?
Thoughts?
Initial test show this is working, but it seems a bit weak - probably because it is a flea watt SE amp. WOuld anyone have thoughts about uping the coupling caps from .047(original value) to .1? Would it help the amp handle the bass response?
Mark
Thoughts?
Mark
Just play with it, and see what happens. What are you driving it with?
