Unique & Distinctive Speakers
Kyron Audio Gaia shown at the Sydney Audio Show - This no baffle speaker system cost $188,000 and features built in DEQX, crossover, preamp and 8 channels of Hypex class D amplification. It takes two days to install, set up and tune these puppies.
Voxativ Ampeggio loudspeakers
www.mademansion.com
Voxativ, a Berlin speaker manufacturer, has teamed up with the most coveted German piano manufacturer, Schimmel Pianos, to design their latest full-range loudspeakers called Ampeggio. The floor-standing speakers merge the traditional horn shape with the rectangular-shaped front in the enclosure, and the cabinet surface is covered in real piano lacquer. Using very special tone wood for the horn cabinet that uses faceted turns to have optimal amplification while eliminating unwanted reflections and resonances. The speakers are powered by Voxativ’s biggest neodymium driver AC-3X with leather surrounds. The sound is optimized purely by the mechanical excellence of the driver and cabinet. The Voxativ by Schimmel Piano logo is made from brass and integrated into the paint and the speakers feature an efficiency of 98dB with 50 watts of power and a frequency response of 38 – 20,000 Hz. $19,000.
Bit more conventional however rather rare frequency response of 20Hz-60000Hz my magnificent Diatone DS-5000 made in 1982 87kg each far superior to my excellent Yamaha NS-2000.image.jpeg
Curious how the signal gets to the tweeter. And what the polar pattern of the tweeter is -- a cone pointing straight up at the ceiling seems likely to beam high frequencies away from any non levitating listener.
Seems like a very expensive speaker for what it is -- a very small two way. On the other hand, you have to respect their laying out all the parts for the consumer to see.
Created by Russian modder Strannik, each fire extinguisher speaker contains two sound units with coaxial-loaded drivers and spring-connector plugs along with a themed amplifier.
