Unsolvable Woofer Pumping (Phono only)
I
So a local audiophile came over with a couple of pre-amps and we tried those. The only time the problem went away was when the subsonic filter that one had was engaged. So, I've ordered some Harrison Labs "FMODs" (20Hz high pass) to see if they will help. If they do, I may order a KAB RF1 one day...but don't want to spend that much if I don't have to.
Any other ideas on what could cause this?!
tl;dr: Woofer pumping not caused by isolation, acoustic feedback, phono/preamp or a compliance issue...what's happening?!
That's what the subsonic filter is for. Save your money on the Harrison Lab filters and such. Been there, tried that. It won't work right at all.
When you tested other TTs, did you still use the same cartridge and stylus? If so, maybe the problem moved in with those.
Thanks. I've already bought them so will try them out when they arrive. If they don't work I'll likely get a KAB RF1.
Trust me on this one: don't bother to open the package. All it does is snuff out the highs and all 'air'. Your woofers will still rumble too.
I like the KASB RF1. I just wish they could get one to work with receivers and integrated amps too.
You may be on to something there! I wonder why this happens with other turntables though. Unless they all for some strange reason have the same issue. I'm thinking of upgrading most of my system, the TT I'm eyeing now is a Music Hall mmf-7.3. I realize they're made in the same factory as Pro-Ject, but a world of difference exists between them I believe.
I have the 9.1 with a 9.3 motor upgrade. Very nice table. AK’s own Gordonw says with an Ortofon 2M Black cartridge the 9.1 will hang with some very impressive turntables. I tend to agree. Very happy with it.
I may as well try, as it's not worth my time/money to send them back. International shipping is crazy. Also, I believe you can get it to work by attaching it in a tape loop (I believe from your tape record out to main in)
Looks like the KAB RF1 has an active filter circuit. These usually work better than the passive one, the Harrison device uses.
My guess would be a combination of two issues. The location of the stand in relation to the speakers, and the stand itself. Since you can tap on it and induce this noise, a certain component of the problem is the stand itself. Especially since other turntables do this. Can you describe it, and how the turntable shelf itself is situated? Is it glass, are there isolation pads between the shelf and the stand?
Secondly, the location of the equipment to the speakers, how far are speakers away from the turntable and gear? Even with going to the concrete floor if you are too close to the speakers you could have this issue.
That would be the two areas I would explore, it certainly would seem there is a feedback loop between speaker and turntable.
Cheers
Mister Pig
loudness function turned on (the issue is still there without isn't this bad until higher volumes
There's a reason why so many of the vintage preamps, receivers, etc had subsonic filters.
I have always used a subsonic / rumble / low filter when playing my stereo. That's about 45 years now. You cannot hear any frequencies that low anyway. That's why it's called a subsonic filter. Its purpose is to prevent your woofers from doing exactly what you are describing.
I was going to ask how high your bass control knob is set until I read that you have the loudness button ON. The loudness button is basically used to boost the bass during lower listening levels. At higher levels it will cause your issue, especially if you have your bass boosted excessively with your tone control knob. This also strains your amp. If you need more bass than what you are getting from your speakers, then perhaps you need a subwoofer.
I understand about the loudness button, but I turn it off once I'm in a louder range of volume. Even at a very low level the pumping happens.
Cheers
Mister Pig
Mister Pig,
Those were my initial thoughts too, until I did the experiment with the digital recorder (recording with no speakers on) and when playing it back it reproduced the same issue. I've tried the turntable on another shelf (wooden table) and right on the concrete floor, no change. My stand is rather cheap, it's glass shelves with aluminum vertical supports. I have my CD transport under the TT, all on top of the top shelf. Vibrapods are under the CD player to further isolate the table.
My stand is about 2.5m away from my speakers at the side of the room. Speakers are at the front of the room...a rectangular shaped room apprx 8m x 3m.
Yep. I have a killer clean Sony receiver that doesn't have a subsonic filter on it. My JVC QL-Y55f will feed back and rumble, but my Technics SL-1301 does not (wood vs. metal body would be my guess anyway). I just wish someone would make an inline subsonic filter between the table and amp/receiver.
Has anyone asked if the record is OK? Warped or out-of-round records can cause rumble. It would be a problem common to other players and doesn't involve feedback or vibration from the speakers.
Can we ask the OP how loud he has his amp cranked up and is he using the loudness button on along with the bass boasted up. If you do that, you won't even have to play music just a needle dragging in a groove with the loudness and the bass boasted will create a situation where your woofers will be over extending.
I've tried several records, it's uniform across the board. :(
I do use the loudness button at lower listening levels, if I take it off the woofer pumping decreases but it's still there (a little)...and increases as I turn up the volume. The bass is up a couple of notches...but I've tried with other preamps and left everything totally flat, the problem still happens.
