Unusual tubes.
62caddy
Trust but verify
Posted on FB today. Any idea what they're for?
the 3-500Z was a popular way illegal CB amplifier tube years back. Its an RF transmitter tube.
not cheap either
3-500ZG Transmitting Tubes (rfparts.com)
probably could be run as a modulator, which is just an audio amp that couples to a transmitter instead of a speaker.
https://tube-data.com/sheets/140/3/3-500Z.pdf
500 watts plate dissipation, in AB2 push-pull it can make some 1400 watts of output with a mere 3kw on the plate.
They're high power transmitting tubes. The 8802 in the top pic is rated for 600watts plate dissipation.
They were also used in some industrial applications for shaker oscillators.
I've seen pictures of amplifiers using big transmitter tubes. the power transformers put out 1Kv or more! Man what a glow from the tubes too!
All correct. I have a 3-500Z tube which unfortunately has suffered a catastrophic failure at some point, and is good for display purposes only. A shame, since they put out a fair bit of power when working, and unlike the audio tubes we're used to, are accustomed to running with glowing red plates:
Personally, I don't yet have an amplifier which uses this style of tube, though I wouldn't mind finding a Kenwood TL-922(A) at some point. What I do have is a Heathkit SB-200, which uses a pair of 572B tubes as finals, and is supposedly good for around a kilowatt:
I bought a SB-220 (pair of 3-500Z) new in the mid '70s and used it for many years. I still have a Gonset GSB-201 amplifier using four 811As that can output more than 1,500W. The choke-input power supply is rated for 1,500V at 1A. I've often thought about stripping out the supply and using it for audio, but the resulting amp would have to be permanently attached to a hand truck. :)
Jack
The 1969 Radio Amateur's Handbook featured a build of a 2KW PEP RF Amplifier using a pair of 3-500Z's. It was good for 15 or 10 Meters (Yes, it would work on "That other band", too). The power supply was separate, but pretty straight-forward.
Cooling was provided by a single muffin fan that just pressurized the underside of the chassis so that air was forced up through the tube sockets.
The various coils and chokes, and how they fed the plates gives it a cool "mad scientist" look.
Article starts on page 201.
Jack
I've been inside of a local 11 meter operators station, two 80k monsters and a professionally engineered 400a utility service. He talks anywhere he wats.......
I've been inside of a local 11 meter operators station, two 80k monsters and a professionally engineered 400a utility service. He talks anywhere he watns.......
Like fishing with dynamite for a hobbyist, not much propagation challenge. What's the antenna array?
How's he hasn't had the visit from the feds? Remote country living so he doesn't get into folks cable TV and household appliances?
I
the 11m band for years has been pretty much a free for all, so long as you don't cause problems with anything. With that kind of power it pretty much demands living in the middle of nowhere though.
You guys familiar with 11m might of heard of him, Bullet Bob, lives in a very densely populated neighborhood and has the nicest house in the area. Couple of antennas to choose from, the big one is a custom design by Prime Minista (aka Sir Mix A Lot). Not my cup of tea but.......
I get down on 11m with my 2 x 2SC2290 RCI 6300F150 @ around 220w in my truck and talk coast to coast daily.
567 Caboverbob on the west side.......
And ya, my station is very small and I always try for the other small stations, all that power takes the challenge out of the equation.
I occasionally check 19 on a Sony 7600G travel portable, sometimes a quick bandscan when I travel, almost no activity, even near interstates. Assume main users now otr truckers as past times for chat and road cdx.
I haven't actually turned any of my stuff on in a long time. Most of the guys I used to talk to have passed on. I should see if anyone is even on the band anymore. I have a range of stuff from the middle 60s through the early 80s and its all covered in dust. The tube gear I'd have to bring up on a variac, its been so long that I'd be afraid to try and shock it back to life.
Fly fishing vs magneto fishing.
I used to participate in bcb DX contesting with passive crystal receivers, not dissimilar to the sophisticated Marconi era passive sets before regenerative tube detectors revolutionized reliable long distance reception.
Nothing like the Philmore or Cub Scout oatmeal coil sets, they are usually double-tuned two circuit loose coupled sets with impedance matched high sensitivity balanced armature headsets. Maximize sensitivity and Q while minimising insertion loss, Ben Tongue (R. I. P.) dedicated a website to the technicalities, which is available.
Guy in Hawaii used to almost always come in first, I could never jump the Rockies from here, KOA Denver was as far West as I could grab.
Fun times, still have a couple of the sets.
