In this situation, the zener works. This is because the current drawn is low ( less than 20mA). Let's just hope the 42V will never drop below 37V and all will be ok.
But case in point, if you require high current to...say power the power amp output stage, it is not as easy. I actually layout a board like this but with voltage divider like the original circuit using resistor. If I don't leave enough headroom, the raw voltage dip below the regulated voltage and cause problem. BUT BUT, if you give more headroom for the raw voltage to dip, the pass transistor gets hot really really fast. I could not find a reasonable middle ground. I already use a 12W heatsink for the transistor already, it heated up like in 1minutes!!!! I am not going to use a big heatsink just to do regulated supply!!! I think that's the reason all the talks about filter caps and ripple on the rails, people still use good old rectifier/cap and put up with the ripple. Finally, I just go back to rectifier and tons of caps!!!!
This idea sounds like a good idea until you try to implement it for high power application. I am going to study SMPS design when I have time, that will solve the problem with a SMPS.
