I use those BXI isolators under my modded AMT3's. They are on a wood floor-along with moving them 12" from the wall the bass is perfect, and the whole speaker has snapped into focus-from top to bottom.
It's amazing when you finally get your speaker really tuned to your listening room, it's like YEAH!!!
Been basically a year long process, sad to say.
The BXI's were a god send, so tp speak.
Along with foamed lined walls, included the rear, 2 added baffle braces, and internal ceramic coating-each speaker has 4 lbs of r-19 fiberglass in pillow cases.
It address a 2 fold issue. Tames the resonance impedance peak of the 1040SF due to the AMT3 cab being slightly smaller then ideal (2.7 vs 3.01-3.3 cu ft)- Qtc .707-.68, and also tames the resonant AMT3's cabs-something it took me awhile to realize I was dealing with 2 equally 'important' issues.
Poly fill just doesn't cut it.
The end result is amazing-fast clean, superior transient response bass that keeps up with the Great Heil, detail and level wise. A lot of work-too much probably.
It's really too bad ESS didn't, or still doesn't stick with sealed bass-as there are ways of compensating for the decrease in efficiency. Dual 10" woofers help-automatic 3db increase-but there are other ways obviously.
I've just never heard a BR alignment passive, or ported that has the same superior response, and "touch" a sealed cab has.
Efficiency is a good thing, but detail IMHO is more important vs a few db.
