klamsoss
Be willing to fail and try again.
Good morning race fans!
Relative newbie looking for some input on a DIY bench power monitoring station...
I have been working on tube gear for a year or so and the variac is a great tool. I have a 15A staco unit that weighs enough to use it for home defense. I also put together a DIY AC meter stack. See pic 1. I plug my meter stack into the variac and that allows me to monitor both VAC and current (up to 3A) as I bring voltage up with the variac.
Now I'm doing some solid state amp restorations and I understand that a dim bulb tester is a MUST. I also understand that for performance testing higher power solid state gear, I may need more than 3A. My bench space is limited (isn't it always?) so, my plan is to do more with less real-estate by adding a switch to the stack, and a similarly metered 10A side with a dim bulb tester built right in line. See pic 2 for schematic: black is hot, yellow is neutral, green is ground. Fuses are marked with an X.
This would give me a 3A side, and a 10A side each with accurate-to-their-range meters, fuses before the meters, and the ability to switch back and forth between them, all while monitoring incoming AC voltage. Plus, I have the master switch to shut off the power to the 10A side if my bulb doesn't dim.
Before I cut apart my current "ack stack" (get it...? "AC" pronounced "ack"......... *crickets*) to add the 10A side, I wanted to ask the AudioKarma braintrust if they see any issues with the schematic or have recommendations.
Does the schematic make sense?
Does the ground need to be wired to the switch (I suspect not)?
Would it be wise to add a 2nd switch allowing me to use the 10A side without the bulb?
Any other ideas?
Many thanks to any and all who chime in!
Any other ideas?
This gives me the idea of building a mini breaker just for my test bench, so I don't have to go down 2 flights of stairs to the main breaker panel whenever I short something or forget to turn the variac down.
If I'm unlikely to ever need to specifically monitor AC line current while testing solid state gear, then omitting the 10A meter in my proposed setup would save me some trouble and I could fit the bulb fixture and switches onto my existing rig. But it's not that hard to rig up a new panel, either, so if it IS likely that I'll want to monitor AC line current over 3 amps, I'll just build it in now.
