Audio fan1
Hi all,
Long-time lurker, first-time poster. I recently found a Fisher 400 on the street and I want to start the process of restoring it. Serial number is 80262, which I understand puts me in the 48001-and-up (version 3) camp.
I'm getting ready to replace the selenium rectifier with a W04G silicon bridge rectifier and need some guidance on the correct dropping resistor value for my specific version. I've read that the bias supply rectifier was already changed to silicon at the factory for units above 48001 — does that mean I may only have one selenium to deal with (the main power supply), or should I be looking for both?
A few specifics about my situation:
- Unit appears to be all original inside, tubes still in place
- I have not powered it up yet... planning to use a dim bulb tester for first power-up
- I have a multimeter and can measure B+ voltage after the rectifier swap
- I've seen values ranging from 47 ohm all the way to 180-200 ohm mentioned across various threads — what's the right starting point for a version 3 unit, and what B+ voltage should I be targeting per the service manual?
Any guidance from folks who've done this specific version would be much appreciated. Happy to share photos if helpful. Also any other insight on what I should be doing next would be greatly appreciated I have purchased a tube tester.
Thanks!
Thanks!
