That's funny you are asking that now. I just hooked up my old Panasonic hi-fi VCR to do just that. I had to connect stereo rca jacks to the in and out on the back of the VCR and into the vcr1 in/out on my AVR. The thing is, when you record, the default is for the VCR to look for what channel you have selected. I needed to press the INPUT button to select line 1 as my source. Line 1 is the rca jacks on the back which I'm connected to. Works good now. Good luck, and hope that helps.
@Tim64: I was unaware of connecting a video source. Is that step absolutely necessary? I am recording right now and it seems ok.
Usually VCR's can not record audio signal alone; so you need a video signal too.I have a Zenith VR2300, which is a fairly decent VCR. I have been considering making VHS tapes of some of the music I listen to, however, I don't know how to record audio-only tapes. Could anyone create a tutorial, preferably one which addresses the particular VCR I have?
Where I ran into trouble with no video signal was if I tried to play the tape on a different VCR it would not track correctly producing audio drop outs. Since providing a video signal this is no longer a problem.That's funny you are asking that now. I just hooked up my old Panasonic hi-fi VCR to do just that. I had to connect stereo rca jacks to the in and out on the back of the VCR and into the vcr1 in/out on my AVR. The thing is, when you record, the default is for the VCR to look for what channel you have selected. I needed to press the INPUT button to select line 1 as my source. Line 1 is the rca jacks on the back which I'm connected to. Works good now. Good luck, and hope that helps.
