Well, I did get an opportunity to get the speakers set up back in October but I never got around to writing about it.
I dragged the speakers out and did a quick job of reattaching the wires to the terminals. The more I worked on them and moved them the more I felt like these speakers define the stereotype of Chinese made goods, look good from far but are far from good. When applied directly to these speakers I think that statement might be a little strong but I will outline some of the things I noticed.
First, there are three ports on the back of each speaker and several of the tubes are loose. It doesn’t appear as though anything was used to hold them in place other than the pressure of pressing them into the hold in the cabinet. The feet on the cabinets are also marginally useful. The 1” diameter, pointed center feet have a shaft roughly 1/4” long which barely allows them to thread in to the base. The covers for the woofers on the sides don’t properly match the contour of the cabinet. The nuts that are intended to hold the binding posts to the plate they sit on are hallow. Furthermore, I never did get the nuts tight enough to keep the binding posts from spinning. The plate they mount to is plastic and I was afraid if I tightened the bugs any further I would crack it. While most people, myself included, would use banana plugs rendering this issue moot, I found it annoying. Additionally, the line where the vinyl transitions from wood grain to black is not straight. Instead, it wavers a bit as though someone was trying to paint it by hand. Last, while I feel confident the drivers are all authentic Vifa, they really detract from the appearance of the speaker. For a speaker that doesn’t appear to use any type of grill, drab paper cones and dust caps just don’t match the glossy finish.
Conversely, as mentioned before, the cabinets are pretty beefy. They are fairly thick and have added internal bracing. They perform reasonably well when giving them a good rapping with the knuckles.
One thing I can not comment on was the crossover. I didn’t take the time to find it so I don’t k ow what it looks like.
As for the sound, I don’t know that I can fairly asses it. The associated equipment was a Yamaha R-S300 receiver and Spotify delivered from the headphone jack on an iPone 6S. Positioned out in the open of the shop as shown, the bass was overwhelming. I had to turn the bass tone control all the way down to bring it to reasonable levels. I have not had this issue with other speakers I have tested in a similar set up, such as a pair of Klipsch Cornwall’s, but it seems reasonable that the side firing woofers don’t react properly to such wide open spaces.
With the bass turned down the speakers did provide some nice noise. All the drivers worked and when you find the sweet spot they sounded pretty good, especially at the price I paid. Sadly, I didn’t really have time to do thorough listening. Even if I had, I think they need to be evaluated in a smaller space to draw more accurate conclusions.
So, what next? I don’t know. I would like to get these inside and have a proper listen, but I doubt that will happen. While they aren’t my Cornwall’s, these are full sized speakers and I don’t have a spot I can set them up for an extended period of time. This means I would need to move them into the listening area, set three up, and move them out out on the same day. This would take an amount of time I don’t usually posses. Considering it’s unlikely I will keep them anyway, I might just sell them off. For now, they are back in the corner of my dads shop.
