Flashback67
Well it has been a month, so I thought I would provide an update on the Frazier home sound system project.
All the drivers are out of the cabinets and the new diaphragms and re cone kits are in. The fellow rebuilding the drivers is picking them up today.
Pulling the drivers from the cabinets yielded a few surprises. There are actually three different models of speaker cabinets used in the home s installation.
Outside there are four units I have yet to disassemble. They have an 8" woofer and a 3" diameter cone tweeter. Strangely the cones are still intact even after being outside for 50 years. Must not be normal paper cones.
Inside there are six sealed cabinet design speakers as shown in the attached drawing I made.
Finally in the houses two bedrooms there are four ported cabinet speakers. These speakers are the same dimensions as the sealed cabinets except for being a inch deeper. The two slotted ports don't exit the front of the speakers however, they exit the top and bottom. This means they exit into the ceiling joists. At first I thought that the drywall had been installed over the port. But probing with some stiff wire revealed they exited into the ceiling.
I finally found the answer on an old AK post. It seems the ported model came in two parts, the speaker cabinet and a port kit that fit on top. They didn't install the port kit and left the opening in covered. My plan is to cover the ports and make the cabinets sealed.
One final surprise was that in one of the cabinets a 4" X 10" tweeter horn was used instead of a 3" X 7" (see photo).
This cabinet was a bear to remove the drivers from. All the others had the tweeters held in by front removable screws. The large tweeter was fastened in from the back. With the small tweeter removed I could reach in to remove the woofer fasteners. With the large tweeter I need to work through the woofer basket holes.
I will be trading the large tweeter for a small one with an adapter plate.
More in a couple weeks.
