coylum
Well-Known Member
Hi,
I am about to start the renovation of a Playmaster 10 watt amplifier ( 4x EL84 version) which has a voltage doubler power supply. On the schematic it shows one of the electrolytic capacitors as "insulated" and the capacitor in question has a thick cardboard cover totally enclosing the can.
I could understand this requirement if the can itself was the negative contact of the capacitor but in this instance the capacitor has seperate contacts for both positive and negative on the base.
Is it necessary to have an insulated replacement capacitor if the can is not connected to either pole of the capacitor?
Cheers, Malcolm
Cheers, Malcolm
