Carbsandcaps
I’ve got a heathkit aa-21 early solid state amplifier that I’m working on. It was a basket case when I got it. I’ve got it to the point where at least it’s not blowing transistors immediately. Right now I’m only working on the amplifier section. I’ve got the preamp disconnected from the main amp and tapped in an external preamp.
I’ve replaced all of the resistors and diodes (not just because but because they were out of spec). App the transistors currently test good and are closely matched. Output is barely anything unless you turn it up all the way you can hear very scratchy sounds only in the loud notes. Almost sounds like random farting. 2 transistors are getting hot and will most likely burn up if ran longer than 20 seconds. Here are my voltages they are a little off especially the driver collector that I have circled is 3 volts off.
I’m also curious about the bias circuit and how it works.
