You are correct.I got some VOTT a while back. They are terrible sounding, no bass, no highs. I tried them with the usual setup I run my NS-1000Ms with.
Any suggestions?
I get that effect from stacked Minimus 7's.You are correct.
Read this, and decide whether you want to pursue solving the problems or bail:
http://audioheritage.org/vbulletin/showthread.php?p=10471#post10471
VOTT does not translate well for home use, their single redeeming feature being imaginary gonadotrophic effect.
You must invest in upgrades, and perhaps additional gear, to render them listenable, including subs, multiples preferrably.
Post what drivers and horns you have, if you want to go ahead.... :yes:
For some, there's less "enhancement" required, obviously. :yes:I get that effect from stacked Minimus 7's.
If that's what he's running, then I understand why he isn't happy with the sound..
Not so much, anymore, Simi:Oh.. BTW Zilch.. yeah.. they are impressive to look at..:
]Well, that'd be a start, certainly....I bet I know how Zilch.. Removed a pair?![]()
1) Doesn't matter the woofer; the VOTT hybrid bass horn cannot deliver extended bass. Midbass is excellent, if the woofer is on top for best integration, but subs are essential.OK, I'll post then
Drivers = 515B
Horns = 805B with 288 - 16G (or 811B with 806A)
Crossover = N809-8A
what's the verdict???
I do, Simi. Not sure I ever posted it here, tho....You had some 902 data didn't you Zilch?
I do, Simi. Not sure I ever posted it here, tho....![]()
Well stop wasting daylight!!!
I did see the info posted on the heritage forum, but it was pictures of the guys meters.. not as easy to figure out..
