Afternoon Gents,
I am the proud new owner of VPI 16.5 RCM.
I've heard that the pick up arm with the felt pads should be changed every 200 records or so. Up here in Canada they run about 30 bucks a pop.
Seems awfully expensive for a piece of plastic with a little bit of velvet glued to it.
Anyone had any luck with making them yourselves?
Thanks,
Wayne
Congrats Wayne, welcome to the 16.5 club.
So far, I've cleaned about close to 400 LP's with my 16.5, and still have the original Velvet Protective Strips on board. You should be able to get similar results, and get between 350-450 LPs cleaned, before needing to replace those strips.
I won't throw a disgustingly filthy record on the VPI, until I at least do a dusting with a small LAST Applicator Pad. Basically, the same material that's on the VPI, but White in color, and these little applicator pads come with products such as LAST Preservative.
I also wipe clean from time to time, with a little Distilled Water, and a soft Toothbrush. And when I'm done, I always remove the Wand Assembly from the Machine, flush with distilled water, pat dry, and set on the side off the machine to let fully dry. This also helps the Recovery Tank fully dry out.
Don't forget these three important rules, and you'll be fine. One, leave the Lid open when doing a cleaning run, it is not necessary to close each, and every time. Be careful never to close the Lid on the Vacuum Wand when it is swung out of the way for record removal, you can easily crack the Wand. This is how 90% of Wand damage occurs.
Two, get in the Habit of periodically draining the tank, while cleaning. You'll get the feel over time, when it will be appropriate to drain the Tank.Slightly tipping the machine rearward will help aid with more removal of fluids from the Tank, and always fully drain the Tank when done cleaning.
And last, always insure you have the Hose Clamp fully clamped-closed while using the machine.
Dokblues makes mention of cutting the Velvet Replacement Pads for the Mobile Fidelity Brush Pads, and using these. I looked into this, as I have some on hand, and the Mo-Fi replacements were a bit too short in length to work like the originals.
The Disc Doctor sells replacement self adhesive velvet strips specifically for this purpose, and they are four for $15.
Provided your Wand is not damaged-cracked, one does not have to necessarily replace the entire Wand. Peel off the old strips when the time comes to replace, wipe the acrylic wand with some high percentage alcohol, then peel, and stick the new velvet strips. The Wand can be removed from the Tower Assembly by pulling it straight out. Do not twist, or bend the Wand, it can crack. upon re-installation, if if ever needs to be replaced, there is a Locating Pin on the Tower, and a Slot on the end of the Wand, to insure proper alignment of the Vacuum Slot in regards to the surface of the record. The Slot is not exactly 90 degrees perpendicular to the record, but ever so slightly tilted by a couple degrees, to aid better fluid removal.
Hope this helps, and keep us posted on your experiences. Lots of 16.5 users here to help out! Mark
