VPI Classic alignment - looking for mint protractor
Well if football is a game of inches, then turntables are a game of millimeters (or less). After a lot more album sides I noticed IGD still rearing its ugly head. So I decided to re-tackle this in daylight, and with a chair to sit down and really focus. Here is what I noticed:
1) Overhang - the VPI jig and the Mint are pretty much in agreement here, with a big (or small) caveat. That is - the "dot" that the stylus rests on with the VPI is comparatively huge compared to a stylus point. The Mint on the other hand uses a very tiny line that is much easier to get right. This means you can be "on" with the VPI but still not quite aligned with the Mint. I double checked with the Mint and this was spot-on.
2) Alignment. This is where the Mint shines, and as I learned today you really have to extremely patient and focused to get it right. The challenge here (as with last year and the other Transfiguration I gave up on) is the tiny cantilever. You can't see it with the 10x loupe that the Mint comes with because the cart rides so low. I was able to find an old 5" magnifying glass that really helped out here. And what I found is that the second challenge - the VPI Unipivot arm - really works against you. There is no "sliding" this arm on the cueing rest to get the alignment right. If you give it any lateral motion, it simply "rolls' over and then rolls right back. You have to lift it, then set it down again. Try that a dozen or more times as you try to get the stylus into a sub-mm alignment window on the Mint and you'll be ready for a double of your favorite booze before long.
Eventually, I finally dropped it right into the sweet spot. Low and behold, the stylus was cocked a little too inward relative to the reference lines. Now you need to loosen up the cart just enough to rotate it an extremely small amount and without changing the Overhang. Blow it and you're back to #1 and starting over again.
Tiny adjustment made and #1 re-checked I played a record's inner track. Hmm...better...I think. But I ran out of time....further listening tonight is required.
I'm beginning to appreciate that better carts with tiny stylus profiles need *extremely* careful setup. Even being off by a tiny amount is a big deal in this world.
Touchdown ? it's still being reviewed in the booth...
jblnut
Changing VTA alters overhang at the micro level. I sometimes play around with the VTA if it looks absolutely spot on the the Mint. it is interesting to hear the changes.
For issue 2, I agree about a unipivot. However, a halfway up lift and then letting it down gets me small lateral movements. I guess Im used to it now.
So...the crowd is gone, the food is put away and it's food coma time on the couch. Time for some serious chill music...out comes my late father in law's original copy of Brubeck's 'Time Out'. Suddenly it is 1959 again and the band is in the room with me. I can hear every subtle stroke of the brushes on the snare and every cymbal stroke is just slightly different that the last. It's real and it's magic. All detail and no fatigue. This is what I have sought in vinyl playback for so long. Finally aligned and singing from the same script, the Classic and Transfiguration have put their disagreements in the past and are getting along famously.
Touchdown!
jblnut
