Kreshna
...but I have to know.
Based on look and model number, it seems Sansui BA-2000 is the lowest end model of the BA-x000 series, with BA-5000 on top, BA-3000 in the middle, and BA-2000 at the lowest rung. However, things may not quite that simple.
First, the reviews and opinions. I have read positive opinion on Sansui BA-2000, where the amp is described as "very smooth" and "has a holographic sound" --exactly what I expect from what so-called "Sansui sound", because my AU-7900 is also very smooth and has holographic sound stage.
The BA-3000, despite being more powerful, doesn't get as much as favorable opinions. For example, it's described as "standard rapidly built crap" and "has issues of its own". I also remember reading somewhere that Sansui BA-3000 is just a cheaper, afterthought version of BA-5000, which doesn't sound nearly as good.
Then, the generation. Both Sansui BA-5000 and BA-3000 were produced in 1975-1977 period, while the BA-2000 in 1977-1979 period, thus giving me the impression that the BA-2000 belongs to a different generation and (probably) different design, instead of merely being a lower-powered version of BA-5000 and BA-3000.
And last, Sansui BA-2000 has different input sensitivity than both BA-3000 and BA-5000. The BA-5000 and BA-3000 has 0.7 volt input sensitivity --similar to the power amp section of the AU-xx00 integrated amps (like AU-7900). The BA-2000, on the other hand, has 1 volt input sensitivity, which may indicate that the amplifier belongs to a (probably slightly) different design. Also, the lower input sensitivity of the BA-2000 (the lower the voltage number is, the higher the input sensitivity is, am I correct? Thus, 0.4 volt is a higher input sensitivity than 2 volt, am I correct) may indicate a good thing, because according to this article, higher input sensitivity means lower noise figure.
So, is Sansui BA-2000 a better-sounding amplifier than BA-3000, despite its lower power? Has anyone listened to both amplifiers and compared them?
