Titanstats... I was asking about the necessity of huge numbers of watts when it is pretty clear that under typical/normal listening sessions, most watts go "unused." It was my HOPE that there would be some amp/receiver manufacturers that haven't bought into the wattage wars and made <50wpc amps/receivers and used quality audio components in the rest of the amp/receiver. From what I've read in response to my original post is that's not gonna happen.
There are a few new amps that I would consider buying if I wanted a good quality amp in the 40 wpc range. This Marantz is just one example. http://www.audioadvisor.com/Marantz-PM-6005-Integrated-Amplifier/productinfo/MAPM6005/
Yamaha, Onkyo, and NAD also make competing units.
Or better yet...this Rega Brio-R
http://www.audioadvisor.com/Rega-Brio-R-Integrated-Amp/productinfo/REBRIOR/
This is a perfect example where SQ is the #1 priority, not advertized power.
If you can believe "Them"!
The only new amp I've heard is the Yamaha AS-500, and I've got to say, it sounded pretty darn good. Yamaha's ace in the hole is it's variable loudness control. This amp was designed for power wars though, so I don't know how much SQ or Durability was compromised.
You do. I have even smaller room. 300W per channel is barely sufficient. Speakers are B&W 802D - they work surprisingly well in that small room.Have we discussed room space? My room is about 12 x 16 with 9 ft ceiling. So don't need a bunch of power for a small room. Or do. I?
The amount of power you need depends on:
1. Choice of speakers.
2. Preferred listening levels.
3. Size of listening room.
4. Distance of listener to speakers.
5. Dynamic range of music.
Anything beyond the needs of the above five, is overrated.
Also, IMO, watts don't tell the whole story since a high current design is more important to me. I'd rather have a high current 50wpc design than one that delivers 100wpc but with less current. In that regard, wattage is overrated.
50 watts on 15" drivers with four horns is going to be pretty damn loud most times...If you purchase a 50 watt mono amp and want to power a 15" loudspeaker with 4 horn tweeters, and expect it'll be enough to give sound to everyone in a rock concert arena, you'll be sorely disappointed.
This is not even the beginning of the beginning of the list. For many manufacturers, the sweet spot for sound quality was in the 40-60 watt range as the parts bins had more to work with in terms of components.
Are the wattages actually variable? I was under the impression only the gain is actually adjusted with the volume pot, not the actual wattage output. That is, the unit always makes X amount of wattage, with the actual gain adjusted to compensate how "loud" it actually gets.
Put 20 "watt RMS" speakers to an amp that puts out a colorful 150 wpc and turn the volume up 1/4 way and watch what happens.
There will always be people chiming in about how much power they need and how much they have got stacked up in their little man caves, but at the end of the day, when electricity costs skyrocket, we'll all need efficient amplifiers and speakers
What defines an amplifier as high current? Are you saying that an amp with a higher ratio of voltage to current produces "better" power? I would have thought that any amp capable of providing the power necessary to deliver a clean signal to a given load would be, inherently, a "high-current" amp?
Generally double the power each time when load impedance is halved. Down to 2 or even 1 ohm.High Current was a buzz term used by HK and others in the 1980s to differentiate amps that actually had decent transformers (as compared to the high dynamic power designs of the day) and enough output devices to deliver reasonable power into load impedances under the usual 8ohms.
It's simple: a power supply that doesn't droop under all reasonable loads and an output stage that can deliver the full capability of the power supply without self destructing = a high current amp. I call it a well designed amp.
Except it can't work that way at any given load....
E=I*R and all that.
In the example given to which you replied, it's impossible for an amp to deliver 100W at less current than a 50W amp into the same load.
There are indeed not many really high current amps.If that is the definition of a high-current amp, I would say that there are not more than a handful of them out there.
Wattage is one measure, instantaneous Current capabilty is another![]()
Quality amps of lowish wattage can and do deliver well upwards of 20 amps when the music signal calls for it. Mediocre amps don't even list that in their specs.. but their wattage info is front and centre.
Headroom is the name of the game.
Frankly if using Realistick and EPI .. it isn't of concern.. imo.
