Ways to safely transport speakers?
Yeeterkeeter
Kermit the Frog
I need to move my pair of JBL 4301B’s to my new apartment, which is two states away. I was going to pack them in 2 big cardboard boxes with lots of packing bubbles with the covers on, but do any of you guys have methods that you recommend I use? I am transporting them by car.
Styrofoam sheet insulation is my favorite packing material for heavy stuff.
Peanuts or bubble wrap should never be used for packing audio gear.
Use rigid foam board insulation. Available at HD and Lowe's. Wrap/seal the speakers in plastic, line the bottom with a cut sheet of foam board, insert speakers, fill the open areas around the speaker with more foam board, 1 to 2 inches or more if needed on all sides. Tape the boxes and you're ready to move them.
I packed my entire setup for a long-term, long-distance move.
I used foam to cover the drivers. Since I knew we were moving, I had been saving all the foam inserts from anything I could. Then I wrapped the speakers in moving blankets I got from Harbor Freight and put all that into big boxes I bought online. Since everything was going to spend at least a year in storage, I also covered the speakers in really big plastic bags and put packages of desiccant in with them. You don't need to worry about that.
Peanuts make a mess and can shed so I get that.
What's up with bubble wrap? I've worked in electronics for a long time and have regularly seen very expensive and very sensitive equipment packed in bubble wrap including in the defense industry.
It’s not about the mess, peanuts and bubble wrap don’t immobilize the item. Once it gets moving it makes more and more space, hard corners bust through and that mayhem guy takes over from inside. For protection from the outside double boxing with corner spacers is recommended.
This maybe overkill for what you’re doing, but it works.
Never use packing peanuts!
I worked in the shipping industry for decades and I have never seen a properly bubble wrapped component damaged in shipping. The ones I've seen damaged with bubble wrap installed are those where insufficient bubble wrap was used to protect the item shipped. For instance, items allowed to "bounce" around inside the shipping box because of insufficient bubble wrap will get damaged. Large, heavy items wrapped with only one or two layers of bubble wrap will suffer the same fate due to the shipper's rough handling.
In this case, a 20"x 12"x 12" sized speaker can be properly wrapped for safe transportation with quality large bubble wrap, especially if the speaker owner is personally transporting them with their vehicle. That being said, I believe foam sheets is best for medium to large speaker shipment via a shipping company
They aren't big or bulky speakers. I'd just wrap beach towels around them and lay them on the back seats.
I guess that would work best for my situation. I am probably going to wrap the towels around the speakers like a present, using tape so that they stay secure. The speakers will also be surrounded by other stuff, so movement won't be a problem. As for preventing driver damage, ill put bubble-wrap & a thin layer of wood behind the speaker covers to prevent punctures, or something hard and flat.
A long time ago, I shipped Yamaha NS-2000 speakers in U-Haul shorty wardrobe boxes lined with 2" thick styrofoam boards all around. They were then put on a pallet, plastic wrapped, and shipped by boat in container freight around the world. No damage.
I had to move my JBL C37 cabinets with the 030 system in them when I left home for college in 1973 (never came back). They just barely fit in my BMW 1600, and only if I took the rear seat bottom out and put it in the trunk. So I made a plywood floor where the seat went and just stood both speakers up in the backseat. Wasn't enough room for both to aim forward so I had to turn the one behind the passenger seat sideways and scoot the seat forward. I figured as long as they were in the car I should hook them up to what passed as a "sound system" in 1973 in a 1968 car. Unbelievable! I was like I was inside the speakers or the entire car had turned into a pair of headphones. Still have the speakers today. Car has been replaced by several other BMWs over the ensuing five decades! My love for BMW and JBL has continued. :thumbsup:
I just brought a pair of B&W 703 S3s from Chicago to Milwaukee in the back of my Prius. I put packing material and two thick blankets down in the car, wrapped the speakers with bubble wrap then set them in the car being careful not to let anything hit the top of the speakers where the tweeters sit. I put the speakers on their sides in the car for stability. Got them home without a scratch.
This cannot be said too many times. Both of these cushioning materials are designed to be flattened as they absorb the bumps and bruises. Once they flatten their effectiveness is gone. Heavy gear pops the bubbles and the result is the second hit damages the unit. Same with peanuts, they just break apart or get squashed and second hit the unit gets squashed.
Depending on the equipment- bubble wrap alone, can be too fragile, while foam sheets can be too rigid and unyielding (it doesn't dissipate shock loading well).
I've done packing, where I put a layer of foam board around the equipment (like "armor"), and foam board lining the box. Between the two- I put sheets of bubble wrap, as a more compliant cushion.
Since the foam board increases the surface area of the equipment, and also provides a smooth surface- there's no "hard points" to pop the bubbles in the bubble wrap.
I sent a Sansui 9090 receiver by USPS ground, from Atlanta GA to HAWAII that way once. Made it without a scratch. In that case- I punched holes in an inner piece of foam board, so that each knob and switch tang had a cavity where it didn't contact any part of the packing material- the foam board only contacted the faceplate flat surface itself. I then put a second solid piece of foam board on top of the one with the holes, to prevent intrusion by the bubble-wrap to the knobs and switches. The padding material wound up a total of about 3" thick all the way around.
Yes, it was expensive- but it worked flawlessly.
Speakers are generally pretty smooth flat surfaces, and not nearly as dense as electronics. Cover the grill with cardboard (to prevent intrusion), then bubble wrap layers directly on the cabinet, with a layer of foam board lining the box (around the bubble wrap) will usually work fine. Just be sure to use at least 2- 3 inches thick total packing material thickness (bubble wrap and foam board combined), so that there's something to absorb shock loads.
However- in this case- a personal car is a LOT more gentle than a shipping truck. I'd still want to "armor" the cabinets with a layer of cardboard, then wrap them with something like towels or bubble wrap, a few layers thick, and then put them in a box. This is just to prevent errant objects from intruding and damaging the drivers or finish.
Regards,
Gordon.
I do not have the money to ship speakers around the world, nor do I need too. But, if I ever live internationally, I will keep this in mind
There are numerous types of bubble wrap designed for different purposes. If you have an unusual item to transport, you might be looking for something that offers a little more protection than your standard bubble wrap. In addition to the basic grades, there are specially designed grades that offer unique types of protection:
Types of Bubble Wrap
High grade bubble wrap
: High grade bubble wrap, sometimes known as strong grade, is made with stronger plastics that won’t "pop" as easily. This grade should be used any time you are wrapping heavy items, or at times when there is significant risk of the item being dropped. The stronger bubbles will help maintain the cushioning.
General bubble wrap: The most common option is general or multi-purpose bubble wrap. This is made with a medium weight plastic that is strong enough to stand up to most typical shipping accidents. The vast majority of items can be protected from minor issues by using this type of wrap.
Limited or low grade bubble wrap: Low grade bubble wrap generally provides the least amount of protection. It is primarily used to help avoid scratches or other superficial damage during a move because it won’t absorb much shock if an item is dropped or other products shift or slam against it. Do not rely on this type of bubble wrap for padding.
I once sold a 35 lb. Rotel receiver I had posted for sale on eBay to a gentleman in Germany. Prepared the receiver for shipping with four layers of high grade bubble wrap. Placed the bubble-wrapped receiver inside a box for a snug fit. I then wrapped that box in two layers of high grade bubble wrap and placed it inside a larger box for a snug fit. The double boxed receiver was then shipped from Los Angeles to Germany and arrived undamaged to the happy customer.
Put styrofoam corners between the speaker cabinet and the cardboard box. Seal the boxes with shipping tape. Remove the grilles and pack them separately—press-shaped styrofoam pieces over the speaker connections. Secure the boxes so they don't roll around in the car. I like using motorcycle straps (I have many of them lying around).
You should be good to go! Good luck on the trip! :thumbsup:
