I have just been bench testing an AU-719 that I reconditioned for an AK member a couple of years ago.
He complained of losing a channel and at first I couldn't find anything wrong, then I found something, if I tapped the left channel (rearmost) Driver PCB it would burst into oscillation, and go into protection mode. I tried this a couple of times, but I made a fatal mistake - I continued reproducing the fault without using a DBT in circuit, and true to form, disaster struck, 2 fuses blown, +2 OP transistors and 2 driver transistors.
- I was pretty annoyed with myself for that, but was a bit distracted with this particular fault and forgot the basics. All the OP transistor junctions for that channel were blown short circuit, and most of the drivers.
Anyway, today I replaced the fuses & driver transistors and put new OP transistors in, powered it up on DBT, all good, removed the DBT and set DC offset and bias no problem. So I let it soak for a while, to check for DC offset and or bias drift, all good, then turned it off and left it for a while. I came back to it later, but this time I put it on DBT. Fault was still there, one tap on the driver board, and it bursts into oscillation, triggers protection, and the DBT bulb brightens considerably. I have some freeze spray and try all the usual suspects - nothing doing. Then I try prodding a few things - still nothing until I tapped C16 very lightly, (470µF 80V) - and all hell broke loose ! - so I very quickly powered off. Powered on again, and still oscillating, powered off quickly. So I thought "surely not C16" ??? - anyway, out came the driver assembly and I changed C16 - re-assembled, powered on (on DBT of course) - with my hand on the power switch, I tap the driver board and...... clean as a whistle, more tapping, no response, absolutely fine now. Removed the DBT, powered on - more tapping, still fine, conclusion? a faulty electrolytic capacitor !!! (you might think, 'solder joint'? - not a chance, the joints were spot-on).
I tested the capacitor on my Peak Tester, and also on a multimeter, and I can't get it to show any problem at all, It was a brand new capacitor fitted by me.
I can see why it caused such havoc, it's in a crucial spot, any disruption there (random charging/discharging, becoming resistive etc) and the amplifier stage will be all over the place.
I hope the description above might help someone with a similar problem. Or for other problems, just the general fault finding approach, and how getting distracted can have disastrous results.
