Wharfedale Owners Thread
Maybe someone with more knowledge can tell me how to measure this thing. Now that I look at it more closely, it seems the two pots are workeding together and both using that 18uf cap?
Here's the thing that's confusing me. What is it?
I put the feelers out for some assistance, so hopefully we can at least get the 3 cap values (I THINK there are 3 caps, but not 100% on that... I was just messaging with someone about that model... If I can go through them and find the values myself, I'll post them, otherwise someone is sure to come along).
*EDIT* - According to a fellow W70E owner, his are 8uF, 6uF, and 4uF.
That is correct, 8uF, 6uF, and 4uF. But I put in 8.2uF and 6.2uF 10% tolerance only because I couldn't find 8.0 and 6.0. Makes no difference as I'm within tolerance. But I'm sure the OP can find the exact values. I may change mine out again, may is the operative word. They sound very very nice as is. OP, make sure you rotate that woofer 180 degrees. That magnet is heavy and will cause sag and stretch on those butyl rubber surrounds over time.
Thanks, Ray...
I'm trying to figure this out myself. This is Dot Heton's crossover... You think maybe they wired them in parallel or something to come up with the proper value? A factory revision in the line possibly?
attachment.php
Listening as I type... Temptations best-of... "Ball Of Confusion" is playing at the moment... So good... Their late '60's/early '70's hits are Wharfedale domain.
I'm wondering when the factory fire was. I should be able to get a schematic for my W70E crossovers. I'd like to see what was designed for the speaker instead of what the factory floor did to keep production moving.
I've been trying to figure that out. I actually get the impression there were TWO fires, one smaller one (in the '70's) that destroyed a records/archives room where all the old brochures and factory paperwork were stored, and a much larger one later (Sometime in the '80''s?). Not sure though.
The Wharfedale factory fire at Bradford was in 1980. All records were destroyed. The sad part is that prior to the fire I downloaded all the specs of all Wharfedale speakers made prior to the fire but lost them due to a computer crash. That data would be valuable and most useful now.:thumbsdn:
Thanks for that. A lot of different dates have been going around (and I suspect I've contributed some of that myself, based on information I found online). The book I have only covers up to 1978 (the year of Gilbert Briggs' passing), and I saw no mention of a fire.
In that respect, the factory floor was B.I.C. in New York if you're talking about W*0 models sold in the US. That's where the crossover, speaker-wiring, and cab-construction occured for the US models. The Bradford facilities were a tighter ship, based on what I've seen and read, so I suspect B.I.C. may have been responsible for some/many of the anomalies in the W*0 line.
Thanks, Ray...
attachment.php
Would a W70D have the same crossover as a W70E?
I could open mine up and photograph the crossover if it would be helpful.
Art
Here is the other side. You can clearly see the two 4uf and one 18uf. But what is the crusty one across the middle?
Is it even a capacitor?
Correction: I did not download those specs prior to 1980. I didn't have a computer then. They were of Wharfedales MADE prior to the fire. But I did find the specs somewhere around 2001 and copied them. I remember they were of all W60, W70 and some W90 models. I think there were also W50, W35 and W40 models. I've searched in vain to find that source again but no luck.
Art
Different crossovers. The W70E crossover pictured is not the same as my W70E. Am I reading a value of 18uF on that bottom cap? Mine has 3 caps, not 4. I'd take a photo but can't right now. I have a construction crew in the house.
I see your caps are Hong Kong which means your Wharfedale was distributed by The Radio People, Wharfedale distributors out of Hong Kong. How does it sound? It may be different but still good.
They sound great. I've had them hooked up for a month now. At first the tweets were fairly quiet but they have come alive. I'm hoping they improve a bit more after the recap. The previous owner had mentioned switching the polarity of the mids. I've switched them back and forth a few times now. Whatever they are now is right. I've lost track of which way is which. He also knew about flipping the woofers to even out the surround sag. But he never actually said if he did it or not. I'm getting glorious bass so I'm leaving them where they are for now.
It's interesting that the Radio People made these. All the speakers say made in England. I'm sure they sound the same.
It's interesting that the Radio People made these. All the speakers say made in England. I'm sure they sound the same.[/QUOTE
The Radio People assembled the Wharfedale drivers from England into their own cabinets. They were a distributor more than a manufacturer. Look for The Radio People label on the back of your Wharfedales.
You won't hear any difference in bass if you flip the woofers. It's just wise to redistribute the strain off the surrounds from those massive magnets. Your choice. I did flip mine. But as you say, the previous owner may or may not have already flipped them.
