Wharfedale Owners Thread
Here is the label. I don't see a reference to Radio People.
Radio People (Hong Kong) was just a distributor like British Industries Corp (B.I.C.). Yours were assembled in New York at the Wharfedale/B.I.C. cabinet shop using drivers/parts shipped from Wharfedale's main facilities in England. Don't let the Radio People/Hong Kong thing deter ya'. Their cabinets were at least as nice as the B.I.C. ones in the US. Canada had a separate distributor as well
Using a system of 3 Russound amp switchboxes and 1 Russound MM6 impedance adjustable speaker switchbox I now can source my Wharfedales from an Altec 345A, Pilot 240, Yamaha CR-2020 or Onkyo TX-SR502 surround amp with a flick of a couple switches. Plus throw a pair of Polk 10A's into the mix for all amps alone or simultaneously with the Wharfedales. And if I want, add a DFX soundfield as warranted. All sources run through a Music Streamer II DAC. I'm done.
Yeah, even when I finally upgrade DAC's, I'll still hang onto my MSII. It's a great DAC for vintage gear like Wharfedales and tube stuff. I'm already getting some very-serious sound out of my current setup with the MSII in play. The way I see it, it makes sense to pair musical gear with musical gear, and the MSII is a musical-sounding DAC. I honestly wouldn't know which model to buy if I DID upgrade. The DAC market is changing and evolving so fast now, maybe TOO fast at this point.
Gang-Twanger if you want a nice bass beat for those W90's give a listen to Sacha's Song from Late Night Blues by Big Bud. Starts off acoustically mellow then the drummer starts hitting the bass drum followed by a deeper beat by a bass viol. At volume that note will give your woofers a nice workout.
I have to say--no Wharfedale that I know of will get near Altec 19's !!!
Definitely the 19's are a GREAT speaker. The Wharfedales have a different sound. I'm not a fan of horns although the 19's are not as harsh as Klipsch. I would love to hear the 19's with tubes.
gorgeous cabinets on those w90s!
guess i need to learn how to refinish wood so i can redo my w70s. i've been using howards restora-finish and feed and wax but that treatment did not do much w/ the wood on the w70s.
i looked at my old emails w/ the seller of my super 12. he bought it in 55 from a local (DC area) hi fi shop. was TOTL back then. i'll email him and see if he knows the make of the cabinet.
To refinish your cabinets try 1 part turpentine, 1 part boiled linseed oil and 1 part stain. Apply with #0000 steel wool, let stand a couple hours then wipe. Finish with Howards if necessary.
Yeah, total apples & oranges. The 19's would blow away the '90's in the dynamics department, and probably definition as well, but will they give me those warm fuzzies I get with my W90's on tracks like "Edie's Love Theme" or "Cafe Regio's"? W90's rule in that department, especially when tubes and oil caps are introduced. Also, with those in mind, they can be made to work in a broom closet if it came down to it. They do soft and easy very-well (EXTREMELY-well), which really surprised me after what I had dealt with prior to putting the oil caps in them.
At this point, my tweeters are cranked and the mids are backed off just a hair (Dials back the midrange grit and gives them a little added smoothness, which I preferred over running them both full-on). They can be the most-laid-back speakers on the planet if you want them to be, and they can also rock the room. How are the 19's at low, low, background levels?
Both models are excellent with horn instruments, and both are definitely ANALOG speakers made for reproducing analog instruments recorded onto analog tape. CD and other digital playback formats are okay as long as it's mastered from an analog source, but I've found that most digitally-recorded music tends to fall flat when played through my W90's ("Brothers In Arms" is a classic example... Sounds awful, except for Knopfler's guitar), but throw on something like that Bluesbreakers w/ Eric Clapton album, and they will transport you to the mid '60's. How are the 19's with BIA? Are the drums as bad?
I just wanted to show how I'm powering my W70E's. Stromberg Carlson tube amp with 6V6GT's. There are no speakers in the console right now, I like the W70E's so much I might take the tuner and amp out of the console and make some nice boxes for them.
Been messing with these two pots over the past few weeks, trying to tailor the response a bit to suit the placement and the in-room response, and I've gotten some VERY-nice results by setting the tweeters at full and backing the mids off a bit (Backing off on those midwoofer pots helps dial back the level of midrange grit... Can be VERY-helpful with older music, but is also a good way to tailor the "texture" of the speaker to suit your ears. I love smoothness, and the W90's are just the tiniest bit too forward for me with both pots set at full, which is why I back the mids off a smidgeroo (or two :smoke: ). I mean, these ARE basically EQ knobs anyway, or at least that's the expressed purpose, so why not play around with them? I think Wharfedale recommended setting them equal to each other, but there's definitely a little wiggle room there if one feels like making the speaker his or her own.
Here's the setup in my testing area.
That looks seriously-great. Everything matches beautifully. I love the console gear. Are those late '50's or early '60's, that amp and tuner?
I run just a Fisher 800C. I bet those W70E's love the tubes. If the tweeters are not right at eye-level when you're seated in your listening spot, you might want to put them on a small riser, just high enough to position the tweeters at the necessary height. I seem to remember those tweeters being pretty low compared to other W70-type models, but whatever the case, I figured it couldn't hurt to mention. Those look beautiful. Once they get their hooks into you, that's it.
Nowadays, I listen to more funk/soul music than I ever did. Those W70E's should be good for playing that stuff (I've totally-rediscovered Isaac Hayes since I got my W90's... Listening to the "Shaft" soundtrack right now).
I just wanted to show how I'm powering my W70E's. Carlson Stromberg tube amp with 6V6GT's. There are no speakers in the console right now, I like the W70E's so much I might take the tuner and amp out of the console and make some nice boxes for them.
Very nice looking units! I'll bet you've got some real synergy going!
I've admired the looks of Stromberg Carlson's big vintage red coned (co-axial) speakers, although I've never heard them. Your tuner reminds me a little of my Scott 399 receiver; separate controls for AM and FM, and (separate) magic eye tubes.
Currently running my W90s with a bitty HK330A. Sweet! Soon to start on my Scott renew, for tubey goodness for the Wharfedales.
I was powering my W70E's with this tube Packard Bell console. Plenty of power, 12 to 18 watts. But the tube amp has a very blurry sound and probably needs a rebuild.
Sorry about the deflection there, guys... I stumbled upon that while surfin'... By the way, your W90's will go hog-frigging-wild with a 399 doing the powering... I predict a few of these in your future:
:yikes:
:jawdrop:
I've always kind of gauged the performance improvements of the W90's and my system as a whole by the way they make certain favorite albums/songs of mine sound, and it's to the point now where late '60's and early '70's stuff sounds truly-epic, like you can picture them right in front of you playin' the s**t. The "Shaft" soundtrack gives me goosebumps, and that alone is worth the price of admission.
Wharfedale cross reference
Can anyone point me to a site that cross references the different models. I see some as W series, E series?? and names such as Rosedale. If it makes a difference, I live in Canada.
Most of the differences are between U.S. and European models.
This is idle curiosity only. I tried getting a set of Teesdales' but nothing came of it.
Thanks Al
My W70d's have the very rare stands that raise them up about 5".
The loss of bass when they are up off the floor is noticeable.
I find they sound better sitting on the floor and tilted up just slightly.
I use hockey pucks under the front corners.
The Rosedales I have sound just fine flat on the floor.
Art
