Two pairs of W90's, huh? ... Wow... Careful Tyler doesn't get you stacking.
I DO, however, want to try them up nice and high and on their sides (like people do with W60's), but it's a lot of work just doing the measuring/remeasuring with W90's, let alone adding the extra height for horizontal placement, but according to Wharfedale, the W90 can accommodate that type of placement. I think the one thing that keeps me from trying it for real (besides laziness) is the fact that I would lose the mirror-imaging, as well as the effect of having a tweeter at the far-left and far-right of each speaker, which I think in itself adds a lot. But who knows? Maybe having a tweeter at the top and bottom (top-left and bottom-left) would add something even better? Maybe not. I honestly don't know, but I think about it every once in a while. Soundstage-height hasn't been a problem for me, since I have mine a good 10" off the floor (Raising them off the floor like that doesn't diminish the bass performance at all, best I can tell, and High Fidelity [Stereo Review] agreed... In fact, they recommended it, and so do I).
Yup. With W90's especially, adding tubes is a game-changer. It does something to the overall sound that's hard to explain, but it's similar to what happens when you play an old, mid to late '60's tube-cut LP on a nice idler-driven turntable from the same era. That era-equivalent mojo thing happens where the sound just leaps to life. Well, when you get that effect with a pair of W90's, it's quite a thing. But let me reiterate that this effect will really-benefit from a locked-in placement (I'm mainly talking about the baffle area here, and having the L & R sides equal distance from the centerpoint of your listening spot). When the planets are aligned, so to speak, the W90's can be pretty-amazing. But their design really-calls for it. They can sound pretty-boxy if the amount of toe-in is off by even an inch or two. I mean, for the W90, the negligible amount of tolerance is like 1/4 of an inch. Beyond that, the difference can be quite-noticeable.
The W90 is an interesting design. Intricate, but in no way overcomplicated. Only two capacitors, 8uF and 24uF. The design was initially just a dual 3-way configuration. Just two mirror-imaged 3-way systems wired in parallel. Pretty-smart, actually. Bare-bones simple at it's essence, but man, when it comes to getting the W90 up and running in it's comfort zone, it's a frigging hornet's nest, particularly in terms of placement. I totally see it now, what High Fidelity meant about that. They said that the performance/frequency response depends more upon WHERE the W90 is in the room than it does upon any tone knob settings, at the amplifier OR at the speaker. I'm hearing much more definition in the bass and lower mids now than I ever did, and it had nothing to do with tone settings. However, I don't mean to downplay the effectiveness of the tone controls on both speaker AND amp. They are VERY-effective. I set the ones at the speaker first (Midwoofers at 3:00 and the tweeters just a hair above that, which seems to smooth out the mid-bite some, but that's just a personal preference... The official Wharfedale instructions for that were to have both knobs the same, if I remember correctly, but it's important to check the indicator marks and make sure that the indicator point on the plastic knob lines up... At least one of the knobs on mine were removed at some point and put back on without lining up the indicators, so I have to set that particular knob a little differently to compensate).
After I moved things around and got my speakers as close to the Cardas-approved placement as I could, I went through and tried a bunch of music that had previously been giving me a hard time. "Digging In The Dirt" and others from Peter Gabriel's "Secret World Live" are especially-good now. That's a tough one, a digital recording with digital keyboards, a rack system guitar setup, plus all that crowd noise? Forget it, man. It's a nightmare, especially for Tony Levin's bass (That's a big problem with digital recordings... The bass and other bass-related instruments often sound very-anemic compared to a good analog recording... Same thing can happen with the drums as well... Much harder to reproduce). But now? Levin's bass takes center-stage, nice and clear, with much better separation from the other instruments. Better separation all around. The upper-bass and lower-mids were the areas where I was having the most trouble, acoustically-speaking, but now I'm really-enjoying it.
