Wharfedale Owners Thread
Absolutely true, yet unfortunately both of these caps are 25uf instead of the proper 24uf for mids / 8uf for tweets. Appears to have come from the factory this way as I bought these W90s from the original owner.
D'oooh! I hadn't seen the earlier threads when I replied..........................
Right! I forgot about that. If I were you, I would try to trace the wiring in each cabinet. Sorry but, given the amazing diversity of the W90s (even within the early models), with different physical layouts of L-pads, caps, etc. (hell, your 2 pair are the only ones I recall with a third (stepped attenuator?) pot), I'd be wary of what other 90 owners said about their schematics.
Looks great Prog.
index.php
Ditto on that. Nice collection of Wharfies. The bottom W90's look like the earlier ones. The top ones are undoubtably the W90C's (I'm judging it by the grillcloth for one... They used the same stuff on the W60D... Those W90's are probably early W90C's... I think one of the woofer enclosures in that version is sealed).
The "C" in W90C is just for the W*0C series. I don't think it signifies "ceramic" or anything like that. I think the W90 MKII (the version from '64-'65) already had all ceramic magnets throughout. Not 100% on this, but I'm fairly-certain it's the case. The woofers were ceramic, and I've seen lots of pre-W*0C-type W90's with all ceramic magnets, even though the W70 MKII (also '64-'65) has an alnico midwoofer... You COULD refer to the W*0 MKII models as W60B, W70B, W90B, etc., but I realized over time that it might make things even MORE-confusing. Just don't confuse those MKII models with the W*0D MKII models (W60D MKII, W70D MKII, etc., all of which have purple mylar dome/pressure tweeters), which I believe are '69-'70. Different series/era.
The W40's are early '60's ('60-'63). The horizontal way you have them is just like they were shown in the advertisements. Placed on their sides (Don't try to mirror-image those... Just put them so that they both look the same). I bet those, with oil caps on the tweeters, would make a nice office/den setup with 15-20wpc of tube power.
So, let me get this straight...You haven't heard either pair of W90's yet, or was it just one pair that you hadn't heard (You've already heard the first pair, haven't you?)? Either way, you're in for a real treat.
Jeez, ever since I brought up Tito Puente, I can't seem to stop playing that album. I love this stuff from Cuba and Brazil. Was all over it last night. It's not that far from the Latin-tinged percussion of Santana. I have Ben E. King's "Spanish Harlem", another selection for the great vintage Wharfie soundtrack of our lives (I have the US mono 1st-pressing LP of that... Great album... I like bongos, cowbells, and all the percussion that occupies the mids/upper-mids).
Stacked W90's...... Madonne...... It'll be wild if that really-works.
I can't listen to them yet but here is The Stack. Waiting on caps, binding posts, and wiring before I can get them cranking!
As GT can attest I have had a similar sick fantasy of stacking w90's for a while now - glad to see you are following through! I was going to borrow my buddy's pair to try it out, but they are not easy to transport (as you know) and I just never got around to it. My Marantz 8b has some real grunt with my w90's (much moreso than any other 7591 or 7189 amp I have tried) which is what made me think it would be up to the task of single handedly powering 4 of them. Sounds incredible with just my pair though - a perfect sonic fit in my small listening space - 4 might be too much but I guess I'll never know until I try. Your space appears to be smaller than mine - I would suggest some OC 703 panels on the side walls at each speakers first reflection point, I think it really does wonders for the imaging in a small space. I'm curious to hear your impressions when you get the stacked w90's up and running!
:beerchug:
I originally thought the bottom pair was the older pair as well, but all parts inside are labels 6/65 on the bottom pair and 7/65 on the top pair. The top pair is a Radio People set and the bottom pair is from the UK. These are identical as far as parts with the exception of the caps, speaker cable terminal, and grill cloth. Since I've already recapped the top pair with Sonicaps, I'm tempted to use the exact same caps for the bottom pair so its a true "stack." Im still considering the options.
I listened to the top pair for about 6 months before I ordered the Sonicaps. They were amazing and of course the inspiration for wanting a 2nd pair, i'll probably pick up a 3rd pair if I can find an all alnico pair for $300 or less. The top left one is ready to go once I replace the L-Pad but the right needs all new wiring from the Xover to the mids and tweets because all of the rubber sheathing is crumbling off!
Thanks for the clarification on the model numbers. I think both sets are W90Cs.
I agree about the PIO caps for the W40 tweets. I'll be looking for those soon as I figure out what to do about the rotting woolen surround.
:beerchug:
I have the panels. They'll fit better once I find a proper component rack. I need those extra inches to properly toe-in the left stack and add room for panels to nudge up against them. I also have a bass trap mounted where the ceiling meets the back wall in the center.
My Scott 222D is 7189 based and its only rated for 22watts per side. I'm not sure how well that will pair with the stack of W90s, but wouldn't hurt to try right? I know the Sony will handle it just find because I had some stacked AR3As going for a few months without issue.
If the 222D is your only tube-powered unit, I think you'll be pleasantly-surprised. 22wpc will be enough. Even at that point, I think they were only rated for like 40wpc. Regarding your drivers, they were made only 3 months after Gilbert Briggs retired from running the company. Not enough time to radically-change anything. Your W90's COULD be late W90 MKII's, but what you want to do is look for a date written inside the upper rear panel. Mine say 9/'63, same date as my left woofer. I haven't checked the rest of the woofers. The date inside the crossover box MIGHT be the date of assembly, but Im not sure. It could be that the DRIVERS in my W90's were all impedance-matched and assembled on that 9/'63 date, but I have no way to prove it yet.
At this point with my W90's, I'm looking to kick it up a notch in a couple key areas. A little more grunt to the bass is one thing I'm after (Fishers are very-laid-back, and I've had mine for several years and would like to try something a wee bit more-forward in the bass... I don't mean to downplay Fisher... Their tube gear and W90's are really a match made in heaven, but I need to broaden my horizon... The Fisher is not going anywhere). Also, as part of their relaxed, laid-back, non-fatiguing sound, Fishers also have laid-back vocals, which really-helps with a lot of music. I'm just looking to try something with the vocals maybe a wee bit more-up-front. Not a big change, but just a change of pace. I think a Marantz 8b and the right preamp will fit that bill. My biggest pet peeve about Fisher is that damn volume knob/power switch. Biggest problem area with Fisher gear.
I'm actually thinking of adding another 3/4" of height to the stands. I need to go to Home Depot or the lumber yard in town and pick up a couple more boards to stack on top. It's not perfection, but a couple cinder blocks and some flat 12" x 32" boards make an easy, fully-adjustable stand for W90's. The bass doesn't seem to lose it's punch and depth at all when they're off the floor. High Fidelity said the bass was just as good at 4" than it was with them flat on the floor.
You guys know how it is... Too much to-do's, and not enough to-don't's.
I need to get on that. I want to try the Russian 2% ones, best matched pair I can get my hands on... I want to try a cap roll on the midwoofers.
Hadn't played the Beatles in a while. This sounds good. The W90's kill on this stuff. The 2-way W60's are an especially-good Beatles speaker, deceivingly-so.... In that respect, the W60 and W90 are one and the same.
I'm thumbing through my Beatles digital collection right now. Earlier, it was the early Canadian "Rubber Soul" CD with the '65 mix instead of the remix. Now I'm in the middle of the de-emphasized "Abbey Road" Japanese 1st-pressing. I love side two. Funny how the pieced-together side ends up being the best side.
Finally hooked my new to me W90D's up the other day and found that all 4 purple tweets are not working, going to crack them open soon but my gut says they are gone. There have been many discussions about finding replacements on AK and I will do my best find some since I want that all original Warf sound. My question is do you think the Morel MDT-29's will be a decent alternative as there is no telling when I might be able to find all 4 replacements. Also, do you still think the Rike caps are the way to go on the 90D's? Thanks!
Bummer about the tweets! My Quested H108 speakers have those Morel tweeters, I love them. If it were me, I would hold out for original parts. Rike caps are among the best, if your budget is unlimited why not?
Hi JMcG26! Welcome to the Wharfies club. Beautiful speakers you have there. Love that you have the stands for them as well. I have Rike caps in my tweeter networks. 8.2uF caps. It cost more than $150 for those 2 bad boys! They are amazing, but putting them in the midrange crossover as well would be HUGE money since you need 24uF caps. I decided that NOS PIOs was the way to go. I ended up following Crestwood23's lead and installed 3 x 8uF Russian KBG 5% 400 volt caps. 6 of them were slightly cheaper than just 2 Rike caps.
I also had blown tweeters. Fortunately it was only 2 instead of 4. Since you need 4 tweeters you can look at purchasing 4 of the Wharfedale Super 3 tweeters with alnico magnets instead of the purple fried egg tweeters. I found a pair on ebay right away for reasonable cost.
What do others thing about expanding the search to include the Super 3's
Regards,
Brad
What I suggest is to source them straight from a parted-out pair of W90D's if possible, otherwise a modern alternative might be a better choice. The W90 used impedance-matched pairs, as the design kind of calls for it (with that dual 3-way design with two mirror-imaged 3-way systems in one big, subdivided enclosure). I wouldn't recommend sourcing them individually from who knows where. Sony6060 (Used to be an AK regular) helped someone source tweeters for a pair of early W90's, and the owner was very-happy with the results. I'm drawing a blank on the model, but I think it was an Audax. I'd remember it if I saw it. Oh, that's right, it was the TWO25AO. The only thing is, he (the guy with the W90's) had found that ALL his drivers had been replaced with cheapo Pyle units, so he bought two alnico W12's, two ceramic W90 mids, and used a single Audax in place of the dual Super 3's (placing the single Audax tweeters on the outside corner on each cab for a wide, mirror-imaged single-tweeter staging), and obviously, this meant that a custom crossover would have to be fabricated. So, did it work? Yes. But will it work in your situation? I can't say for certain. You're only needing tweeters, so I figure you'll want to replace two with two and keep the W90's sonic perspective intact. Whatever you get, if it's not original Wharfedale, just make sure it's smooth. One of the great things about my W90's is how they are with that older music, and you don't want to lose that.
Last night, I was listening to a really-good oldies CD, all late '50's and early '60's rock & roll classics. Bands/artists like Bill Haley & His Comets, Buddy Holly & The Crickets, Chuck Berry, Danny & The Juniors, Bo Diddley, Brenda Lee, Lloyd Price, The Surfaris, etc. (Probably all on the same major record label), and this CD is beautifully-mastered and has the best-sounding mono tracks I've ever heard. I've played a lot of older music on my system, but this CD is like flipping the ON switch. And speaking of that, I must say, Bill Haley sounds amazing through W90's. I think it's the way they handle that big upright string bass that was the foundation of bands like the Comets, the Crickets, and all those other early rock & roll acts. But it's not just about the woofers. The old Wharfedale tweeters just have the sound for that stuff, especially the Super 3. So, if '50's & '60's music is important to you, you'll want that to be a factor in your tweeter-choice.
Hi JMcG26! Welcome to the Wharfies club. Beautiful speakers you have there. Love that you have the stands for them as well. I have Rike caps in my tweeter networks. 8.2uF caps. It cost more than $150 for those 2 bad boys! They are amazing, but putting them in the midrange crossover as well would be HUGE money since you need 24uF caps. I decided that NOS PIOs was the way to go. I ended up following Crestwood23's lead and installed 3 x 8uF Russian KBG 5% 400 volt caps was the way to go. 6 of them was slither cheaper than the 2 Rike caps.
Regards,
Brad
The W90D has a different design/construction that the earlier, highboy-type versions. He would have to isolate the alnico Super 3 somehow to accommodate it (He'd need to mount a little bowl-type isolator on the back so the woofer waves don't compromise the open-backed Super 3 frame.
That said, some ceramic Super 3's might be doable. That's something to give a lot of thought BEFORE doing. Remember, the W90D IS a slightly-different design, so even though some might consider the Super 3 a better tweeter, the purple one might actually be a better fit to that model. Hard to say.
Man, what is it about the W90's and music from 1968. That must have been a great-sounding era for music in general, that period from '67 to '69. It's probably because it was the last of the tube-recorded/tube-mixed stuff. The last of the tube mics and all that, so the peak of an era, technologically-speaking. I don't know. I love that era though (right before the major label studios switched to solid-state recording/mastering gear).
Thanks everyone for the reply's, was really excited about them and hoped all was well but yeah a little bummed about the tweets. Since they were free I can't sob too much and the hunt begins, I'll actively be looking for purple pairs on the bay and other vintage HIFI sites to see if I can find some but in the meantime I think I will purchase 4 of the Morels and see how that sounds.
bce22, I think I will probably go the same route you did as I am finding pricing out Rikes for all is big money that I cannot spend at the moment. Will keep everyone posted on the results!
Next is to clean up the cabinets and possibly redo the fabric covers.Thanks!
Gang, do you know what the original Ohms are for the tweets, 6 or 8? The W70Ds are so much more prevalent on the bay so I'm hoping I could use a pair of those as they seem to be a match and are 8 ohm. I'll see if I can get a reading of mine even though they are blown. The 60D's used 6 ohm from what I understand.
Sorry, I don't know for sure. The overall impedance was always 8ohms for W90's, even the W90D's I think, so I didn't expect there'd be any 4ohm drivers, but electronics theory is not exactly my forte. Wish I had a better answer for that. It's a good question, and not just for the W90D version. The E90, which came out almost 10 years after the W90D, has a rock-solid 8ohm impedance throughout it's entire frequency range, and my early W90's (from 1963) are incredibly-easy to drive and rated at a steady 8ohms, so I guess I always figured the W90D was very-sensitive and easy to power as well.
My websurfing setup is on life support right now, and I'm having a tough time job. around the various parts of AK (and other sites) and accessing certain things (Thankfully, this thread hasn't been a problem, probably because it's always been one of my regular stops). I'm working on a solution, but in the meantime, I hope folks can bear with me. Truly-sorry for the inconvenience.
