Wharfedale Owners Thread
It all depends upon the definition of 'section'. In the book titled LOUDSPEAKERS, there are two pages, 49 & 50 on the 'acoustic labyrinth', aka transmission line.
I remember there wasn't a lot of information about them, but I don't think it was this book. I remember it being called a Transmission Line Speaker. I liked the idea of getting lower bass from the same volume of air.
Technically, it is a transmission line but way back in the early thirties it was called an acoustic labyrinth by some engineer at Stromberg Carlson. In a way, it does resemble a geometric labyrinth but those are usually much more difficult to navigate, like mazes. Chances are the term transmission line was adopted as it seems to suit engineering jargon. A wire carrying a signal is a transmission line. I seem to remember seeing the term TL in audio publications as early as the sixties.
You may have seen a later edition in which it was called a transmission line. Who knows?
Well, I'm the new owner of a pair of W70Ds. I opened them up today to check out the speakers and capacitors to see if they're original, and to see the baffle mounting.
Speakers appear to be original. I didn't remove the upper mid's enclosure. .
Capacitors are newer Solens, 16uF and 6.2uF.
One of the rear panels needs a new treble knob and a positive speaker connection. I found the treble knob on eBay, but $19 shipped seems a bit much. I may have to just get new similar looking ones. Other than eBay, can anyone recommend a vintage speaker hardware site?
After reading some of this thread, or somewhere on this forum, it appears that PIO capacitors are preferred for this vintage speaker. I'd like to try them, but first can someone confirm that the values of the Solens that are installed are correct?
The cabinets are rough. Some veneer missing. One speaker's grille cloth is torn. There doesn't appear to be any way to pry the grille out from the front. Inside you can see triangular attachment blocks for the front baffle. I can see grille cloth wrapped around the baffle as well.
There are several threads that have information about how to restore these cabinets and grill cloth. Take the time, do the work. They're worth it. Have you had a chance to evaluate how they sound to you?
Yes, I listened to them today for a few hours before opening them up. I thought I was hearing expired tweeters (kinda blare at you, depending on the music), but when I saw the Solens I thought maybe going to PIO caps would mellow them out. Also turned down the mid and treble pots and that helped smooth them out. The PO had them at max. They also seemed more full up on the bench top, rather than on the floor in front of the Fishers. Folk and Rock were the main genres.
I liked their sound. Not knock your socks off, but very pleasant and musical.
Hi. My Wharfedale fascination continues, just this week I was given the opportunity to buy a pair of W70E's, which are rarer that the rare, lesser spotted shy hidey bird in the UK. I guessed the owned had lived overseas and I was right, the father had lived in Puerto Rico. These are in great condition, and completely unmolested. I've had only a cursory play with them so far but all drivers are working and they sound superb. The bass reproduction takes my breath away, again, not overdone just sonorous and cathedral-like. I have them plonked on top of my Rosedales for now, and at that height they sound superb, so I was wondering what arrangement for level others have found best? Clearly they are designed for flooorstanding applications and I've never tried raising my Rosedales but I need to play around now. Anyone else use them on stands and if so what height and what type?
I'm also curious about the 5" unit on these W70E's which have a roll surround unlike my Rosedales which have the felt surround super 5 style unit. Ive not seen these before. Any comments?
I have my W70E's on 5 inch stands with about a 5 degree upward tilt. Wharfedale made stands for these models. They are hard to find so I found pictures and tried to make mine with similar proportions. So @ziggydave glad someone else here agrees with me on the fabulous sound these produce. You're right about the bass - it feels effortless and they do sound excellent on pipe organ music. Go onto youtube and look for the Interstellar theme with Zimmer live in Prague, and enjoy. Be careful not to put more than 25 - 40 watts on these as they will burn up!
Don't worry, I won't overdrive them, I'm just basking in the glorious sound. I never thought I would get to own a pair. My mission now is to determine what, if anything, is different between these and the Rosedales!
They made stands?! I never saw those. Have you a picture of yours? I'm sure I'll find an image online...
Part of the issue with the Rosedales is the crossover. I made copies of the ones in the W70E's which improved them substantially. They use pretty much the same drivers with exception to the mid range driver, but it's not substantially different. I think the biggest factor is the amount of interior volume that the woofer has to itself. The mid drive enclosure is half the size of the Rosedales, the woofer is front mounted, and there are no cleats for the rear panel screws which gives just enough extra interior volume to allow the woofers to really shine. Here's a picture of the one W70E on my home made stand. It's only three
pieces of wood. Two boards cut on an angle to tilt the speaker with a slot and stretcher in the center. I added wedges to the front of the boards to give it the look of a mid century tapered "leg" and veneered it to hide the end grain of the boards. Just used very inexpensive pine with walnut stain and oil finish.
They look excellent. Good Job. I will try something similar.
Another problem I have is the front grill panels have warped across the centre, the cloth being too tight and deforming the strut. I feel they may have been damp at some point and the fibreboard has expanded. Is that a common problem?
Nice!
You should post this on https://audiokarma.org/forums/index...istening-space.130581/page-1072#post-16350375
Just remember that Rosedales run the woofer 180 degrees out of phase to the W70E's so they may not sound very good if you run them in parallel.
BTW I don't see any of the bagging you described on the grills. They look just fine in the picture.
Thanks, I know there are many better setups on here but it means a lot to me because I've built it on a shoestring, everything bought at rock bottom 'fix it up' prices and traded up again and again (and still is... note the tuner with missing side plates and broken case! Still, performance wise she is great now, the rest is cosmetic work. I'm most proud of the AR XB which cost me next to nowt but is just the best turntable ever. And now with the AU-666 driving two pairs of 15 inch Wharfedales, I think I can stop now.
Interesting you mention phasing, I haven't had the W70's open yet, but I know the Rosedales bass unit is negatively orientated, Are you saying the 70's are positive phase? I have played them lots together and there is no indication of phasing issues, the bass is deep and sonorous and wonderful. I was concerned that the front mounted v/s rear baffle mount would be an issue as, stacked plumb the bass units are not aligned but it seems to matter not. This will require some investigation.
and yes, the grills look ok from a distance, and they are in great condition so I'm not going to attempt any kind of repair. If they straighten the straighten, if not I can live with it.
I think you did quite well with your system build. I love my Wharfedales and don't have any plans to ever retire them. I've had Kef's, ADC's, and Paradigm speakers next to them for comparison and none of them had the sonic luster exhibited by my Wharefdales. The only thing I may want to try is changing to a tube amp at some point in the future.
Ditto.. though the Sansui's hard to give up...
One thing you need to know about the Rosedale with that particular crossover: the woofer is run out of phase from the mid and tweeter. I hand built new W70E style crossovers which have all speakers in phase, and replaced the originals so I could run the Rosedales and W70E's stacked if I ever wanted to. I did keep the original crossovers in case someone wants to put them back to being completely original.
infullview, do you have a schematic of the crossovers you built? And a pic perhaps?
