The W70 has several versions in several cabinet styles but the interior dimensions of each series is the same. The styles included a plain box, filigree on the front with no overhanging top and overhanging top with filigree on the front and around the overhang. The outer decoration does seem to make them larger or smaller depending on the style but the interior dimensions where it counts is the same. There were price differences as you can imagine between the cabinet styles so if you equate premium version to price alone, the enclosure with the overhanging top and filigree would be it. Soundwise there is no difference except golden ears may find issues with defraction with the overhangs. Also there was an accessory set of legs. The drivers and layout are the same except for the 2 crossovers used in the W70. The known and noted versions are the W70, W70D and W70E. However, there also seems to be undocumented W70C. The C appears to be the 2-cap x-over. Of course the D and E are not the same design as the original as they changed drivers and also cabinet design went from an open baffle to acoustic suspension.
The 2 cap version of the W70 may be in response to the use of higher powered amps that were then on the market and were possibly creating reliability issues for Wharfedale's 1 cap design.
Smaller cabinets or 2-way systems included the W60 series while there was the larger W90 that does not seem to have survived production into the acoustic suspension period.
