Every dog here deserves many cookies:
Plus all those pointy teeth
Bing AI​
German Shepherd Clamping Power in PSI​
A German Shepherd’s bite force is typically measured at about 238 PSI (pounds per square inch), which is significantly higher than the average human bite force of around 162 PSI German Shepherd Puppies NCGerman Shepherd Puppies NC+1. This figure reflects the breed’s robust jaw structure, strong masseter muscles, and skull design, making them effective in protection, herding, and working roles.
thanks. jvc used green condoms. they fade. i used green leds for the dial and used green film in front of a new incan bulb in the meter.
jvc liked green.
i LOVE the look of this one, i just wish it was 80wpc. not 8wpc
Hook it up to a pair of LaScalas, will take your head off at 2W
I've been waiting for a bigger place for 30 years
so I can pack it with more gear.
For some reason experimenting with the flea weight amps attracts me............
Someday
If you ever wanted to measure an experiment before and after
Metal films for the carbon resisters
30% over on the filter caps, punchy
Better quality modern caps, 1 over on voltage
New diodes in the power supply , better rectifier
Better op amps , lower SN
Hot rod the receiver as a science experiment
If This Bass Could Only Talk
Stanley Clarke
1988 Portrait R 40923
My CD/LP/Tape Collection
Someday
not on this one. but i do alot of that to other, more worthy gear.
funny that recently, i flattened the jvc ax66 phono response like ruler flat using my ebay 'motronix' iriaa board...i just built my own iriaa board and handmatched precision parts and remeasured the jvc...it's got humps where i compensated the phono stage for defects in the ebay board
when i plotted the ebay board, it LOOKED good but i never compared exact dB with the standard. it's off a bit. not bad. might not be able to hear the difference but i could see it.
i'll get back into that unit before long and post plots and stuff when i readjust it.
i got burnt on repairs and restos. i been doing more mods lately...and playing. tinkering. just having fun. :thumbsup:
i'm pretty sure that it had a blown channel and it got new ksd526/ksa596 outputs as well. prol new diff pairs too.
took alot of lamps to light it up.
Don't forget to socket the Op-amps
so you can do op-amp rolling to find just the right one that makes your favorite female vocal sound like she is sitting on your lap blowing in your ear.
While you sip fine wine .......
