And I'll admit that a speaker/ amp change is a tone control for me to change the sound in the room. But the difference is I don't have switches and filters adding noise and clipping off frequencies, it's a short signal path being my advantage.I will admit that the subwoofer serves as a tone control of sorts, though.
The last thing I'm going to do is complain about a specific recording or mastering when in fact it really can be on my end that it sounds bad.
Not all recordings are created equally my friend. There are differences in volume through out the frequency scale on all mediums. One engineer to another, somewhat depending on their opinion on how it should sound. So all the differing influences come to you. Mostly are acceptable. There are occasional times when one may want to dampen or increase a given frequency depending on what they are hearing.
EQ,s add gain. 8-12 DB in most cases. Some do a better job then others. Our volume controls, reign in the gain, dampening power across all frequencies.
During playback frequencies can affect each other. Volume enhances this and a EQ can help by tamping/toning frequencies down or boosting them. To listening pleasure. I love it when a record plays great without it but when it doesn't I find it easier to add a EQ and make changes.
I have two EQ, now. One on this HK Pre so I no longer use the Technics electronic EQ SH GE70, I have been using for years.
Today, using the same system. Same room, sounds better when needed.
Nor are all the masterings of that recording, but then I never said either of them where.Not all recordings are created equally my friend.
The same with the listener, so it equals out as most people will find a mastering of a title they like and it works with their system and space.One engineer to another, somewhat depending on their opinion on how it should sound.
But what does all this have to do with the topic of this thread?There are occasional times when one may want to dampen or increase a given frequency depending on what they are hearing.
I don't understand how you can use a PEQ and then say you will never use one. IME a properly adjusted PEQ only makes the sound better.REW software helped me position my speakers and sub and sound absorbing panels optimally in the room but I still need PEQ to tame the subwoofer room modes...kinda think that’s almost necessary. I have never used and will never use EQ on the main speakers...it just takes too much away.
How does it help to get certain frequencies wet lol?
Yes. Great to be able to do it.Have you looked at 4-2-7's setup?
Kind of like an 80yr old women that looks 100, puts on make up and thinks she looks 40
When the equipment is at a certain level it's just not needed.
That aside.
Have you looked at 4-2-7's setup? If the SQ is lacking due to his equipment I can't see where, and a bad recording is still a bad recording. Kind of like an 80yr old women that looks 100, puts on make up and thinks she looks 40, it's still what it is.
When the equipment is at a certain level it's just not needed. If the music has warts the equipment hides then the equipment isn't accurate. True
If an EQ is put in line to hide the warts it's tantamount to having the inferior equipment that wasn't good enough to reveal said warts. No. It simply changes what is being introduced ahead of the Output of amplification.
No one said you did. I made a statement. Correct it if needed. My point was how these obvious discrepancies in fidelity are compensated for. In your case you changed systems to achieve desired results. I sometimes will lower (dampen)Nor are all the masterings of that recording, but then I never said either of them where.
"What combination of gear and listening space mods finally let you remove EQ"
You can go back and read the OP but all your post in this thread are an argument for using an EQ and nothing to do with the topic. I think they call that thread crapping, derailing threads, switching the topic to suit your opinion and create contention and arguments. I would think if you want to talk about the benefits of using a EQ you would start your own thread, unless the whole point in posting here is really to create contention and arguments.
And off you continue to go,When did the thread change to searching for the perfect recording for your system/ listening space? This was not the point at all.
What color is the sky in your world?After I got my system pretty well set I put my focus on the media finding the best masterings, buying many many dups of same titles as not all records are equal.
