dave g II
i realize it is a weird question but I just received a 60’s era Electrohome console with a Lorraine 40 radio, Garrard turntable and a 6bq5 output amp. Previous owner threw in a nat king cole record box set. I got the TT cleaned and lubed it works great and the NKC record sounds great. The problem is every other record I play sounds like crap. Painful to listen to very harsh highs.
My question now that I will start working on the amp and preamp “will recapping fix this?” Or is newer music just not meant to be played on older gear?
I suspect leaking coupling caps are the issue. I hope
I have a wave generator and a scope. Bought both recently and both are vintage and currently being recapped so I am unable to run a signal through it. I did bypass the crossover and speakers with a pair of Polk audio bookshelf and it still is “shrilly”
I have not found a before and after video on YouTube to hear what a bad amp sounds like so I am reaching out to you guys
Thanks in advance
Thanks in advance
