No - the only modern ceramic cartridges are the ones used on record players such as the crosley cruisers and similar at the very bottom end of the market. Quality ceramic cartridges have not been made in decades.
Maybe you will get lucky and find a Sonotone, a Decca Derem, or maybe even one of the better Ronnette cartridges which still have a compliant rubber suspension. It is really a gamble though without guaranteed results.
Also, how is the idler in the Garrard?
Thank you all for input. MM cart is the way to go. I will start looking for a new phono stage.
I appreciate the quick and sage advice from all of you. Cheers
"What does a bad tube amp sound like?"
A transistor amp
Sorry,couldn't resist....
Agreed.. I know magnetic sounds better but plugging a phono magnetic preamp into preamp that is expecting ceramic cart is going to sound worse than using ceramic. I tried it on my magnavox console. Even though people say ceramic is at line level the preamp circuitry for ceramic still being equalized ususually by having the highs rolled off and bass boost which helps fix the issues with ceramic carts. Without removing that circuitry the magnetic preamp is going to make it sound very bass heavy with the highs rolled off.Just buy a new stylus and move on from there. They're very reasonable in price and may even fix your shrill playback.
i realize it is a weird question but I just received a 60’s era Electrohome console with a Lorraine 40 radio, Garrard turntable and a 6bq5 output amp. Previous owner threw in a nat king cole record box set. I got the TT cleaned and lubed it works great and the NKC record sounds great. The problem is every other record I play sounds like crap. Painful to listen to very harsh highs.
My question now that I will start working on the amp and preamp “will recapping fix this?” Or is newer music just not meant to be played on older gear?
I suspect leaking coupling caps are the issue. I hope
I have a wave generator and a scope. Bought both recently and both are vintage and currently being recapped so I am unable to run a signal through it. I did bypass the crossover and speakers with a pair of Polk audio bookshelf and it still is “shrilly”
I have not found a before and after video on YouTube to hear what a bad amp sounds like so I am reaching out to you guys
Thanks in advance
It uses 6bq5 tubes which should be pretty HIFI sounding.What you got is the 1960s equivalent of a boombox. How do you think should it sound? And stop playing vinyl on it - with every attempt you irreversably damage your records.
There are good sounding tube amplifiers, but you will unlikely find them in a console, unless it was custom made and was ultra expensive in its day - the equivalent of today's boutique high-end.
Agreed hopefully with the preamp on those inputs+Plug the magnetic preamp into the tape or TV input of the console, those are true line level inputs.
Agreed but when the changer shuts off it won't turn the console offPlug the magnetic preamp into the tape or TV input of the console, those are true line level inputs.
Even though people say ceramic is at line level the preamp circuitry for ceramic still being equalized.
