Thanks. If you had it would you use it.? Is it good quality?
I think you can use it like a head amp to boots the volume of a cartridge(Gain) It can also lessen pops a ticks. dependind on your cart TT to inputs exspander outputs to phono stage.
It can also be used between the tape and pre for recording.
Where did they use this type of thing? Radio Stations or music studios? Neither?
I think you are giving this device way too many tasks.
It will boost dynamic range in both record and playback for recordings as well as being a noise reduction device on playback.
Still giving it too many tasks. You would not want to use that unit in recording..., only playback of a signal, regardless of the source.
Because tape only has limited bandwidth, compression is typically applied during the recording process. The signal is then expanded during playback.
But that unit has no facilities (that I can see) to perform compression as is done on my dbx 119.
