It is not totally uncommon to see a resistor inside a fuse.
It is one method used to design the time to blow characteristics of the fuse. Some equipment manufactures will want a fuse with a specific time to blow versus overload characteristic to prevent nuisance fuse failure, while providing safety.
Fuses are not used to protect equipment, they are used for safety.
Doing a search by this "Acoustat DD servo charge mono amp" I found a service manual. It lists 2 fuses. It does not specify any type of special slow blow fuse. If I did not find the correct piece of gear, then disregard.
