Had that with basal cell carcinoma 2 years ago - all taken care.
So all your material issues get on your nerves and this is understandable. However there is a more important level in our life. You are aware of it.
The that was that is part of it too. It got you home. Make of that what one will but many examples. It's a fine line between being aware of possibilities and giving them too much attention.What could possibly go wrong?? Be careful of asking questions like that.
I was taking Emma from home in Fairfax, VA to Hagerstown, Md. on a Sunday morning so she could do the visiting preacher thing at the MCC church there, we were riding in our 5sp 2006 Honda CRV and on the way out, I mention liking the CRV as general transportation, and being uncertain what I'd even replace it with if something happened.
Well, later that day, on the way home I heard an odd sound like a banging on sheet metal kind of sound. and less than a mile from the house I stopped at a stop sign in our neighborhood and it stalled, never to restart again.
I figure that darned thing HEARD ME and tossed the timing chain out of spite! It was loyal enough to get me within walking distance of our house, but that was that.
And thats how I wound up with a Honda Fit ...
My experience is things go wrong in 3s (triplets). You already have that number.Went on a nice relaxing vacation, settling back into the home routine.
That routine seems to include an ever growing list of things that have decided to break.
My garage door opener failed yesterday - came home from an errand and just as I was about to pull in, the door dropped like a guillotine! I barely got the car backed up. Seems like the latch that connects the door to the drive screw broke.
While trying to enjoy the rest of the day, the house got continually warmer. I knew the A/C was working the other day, but couldn't feel cool air anymore. Yup, the fan wasn't blowing.
Monday, we're having the termite exterminator come as we have some on the west side of the house on a long facia run.
And, I'm still trying to find a solar contractor to fix a failed microinverter for my panels.
What else could go wrong?![]()
Don't tempt Fate!What else could go wrong?![]()
Yeah, Fate can take it as a challengeDon't tempt Fate!![]()
The blessing is that it did not burst into flames while you were away!My former neighbor had a pipe break while he was away on vacation. When he got home the water was coming out the small basement windows near the ceiling of the basement. I couldn't even imagine pulling in the driveway and seeing that sickening mess.
In my case nothing quite that drastic but my 18" Def tech sub decided it was time to go to sub heaven during my last extended vacation. Yes crap does happen at the worst possible times sometimes.
Damned, to the flood.My former neighbor had a pipe break while he was away on vacation. When he got home the water was coming out the small basement windows near the ceiling of the basement. I couldn't even imagine pulling in the driveway and seeing that sickening mess.
I had an icemaker line break on vacation. I will never attach another one of those again.The blessing is that it did not burst into flames while you were away!
Our last trip to visit my inlaws was late October. We got home midDay Sunday and - Emma smelled Chlorine as we entered the house. went downstairs and found one of those blankity blank plastic lines for the icemaker that we had clamped off had split from age, popping loose from the saddle valve and was spraying water all over the laundry hanging on a laundry rod, over my open toolbox, and had started flooding the basement.
Fortunately, it appeared it had only been running an hour or so, MAX ... could have been SO MUCH WORSE.
Also fortunately, earlier that summer, we'd had a plumber in to replace the main shutoff valve since it was ancient and no longer worked to shut the mains off.
So we could turn off the main water while I fixed the problem!
It seems that when you fix one part of the house's plumbing (e.g., a stuck shower valve), soon after another part fails (e.g., the sprinklers stop working).I'm sort of convinced there is a required level of broken things in any given person's life. Never seems to fail that when you fix one thing, something else breaks. I was pouring fresh oil into a leaf vacuum that I bought, doing what I thought was going to be the last repair and maintenance item and the carb started dumping fuel out of it.
Working on my diesel to tune the injection pump to reduce the smoke, and one of the brake calipers went bad.
I replaced the caliper and have the carb kit on order. I'm vaguely terrified at what will fail in retribution for this. Half expecting it to be the other caliper, but since I bought one I'm sure it won't be that. My luck it will be a rear caliper, which is a serious problem because they are not available, nor are the seal kits. My fix there will be to steal the brackets off my parts car and convert it to the later style rear brakes that I can actually get.
Vibes man, vibes...It seems that when you fix one part of the house's plumbing (e.g., a stuck shower valve), soon after another part fails (e.g., the sprinklers stop working).
You have awoken the Evil Maintenance Gods.![]()
Yeah, uncorking the bottle of Bad Juju.Vibes man, vibes...
Anytime you change a caliper you should also change the brake hose going to it. I learned that the hard wayI replaced the caliper and have the carb kit on order. I'm vaguely terrified at what will fail in retribution for this. Half expecting it to be the other caliper, but since I bought one I'm sure it won't be that.
That routine seems to include an ever-growing list of things that have decided to break.
I use a syringe to draw out the dirty brake and clutch (if you have one) fluid. Don't draw out every last bit to expose the cylinder holes; that way, you may not need to bleed the system.The hoses were new with the calipers 5 years ago. No issues that I could find, and I didn't drive it long enough for anything to get hot enough to worry about. The hoses I took off were original, 35 years old, and completely shot.
I pulled the caliper apart and found some rust flakes in there. I had flushed the brake fluid when I did the calipers but I suppose its not impossible I moved some rust into the caliper during that process and it finally caused an issue. Probably due for another flush on all of my cars honestly. Two of them have some rather expensive and/or impossible to find parts so if changing the brake fluid reduces the chances of problems I'm fine with doing it.
