What Exactly Makes The MAC 4100 So Great?
The RCA jacks are the one annoying issue with the 4100. IC connectors can't seem to maintain their grip on them with age. Ryan at A/C says the problem is unique to the 4100. I've been putting off having them replaced but it's been getting worse. It's not exactly a small job and will probably run a decent chunk of change.
I know I've mentio
I know I mentioned this before, and agree, the 4100 is picky about what cables one uses.
Yeah, when I got mine not long back, thought I was going to be able to use some high end cables I have, Shunyata, and Audio Sensibility. Nope, they were both no-goes.
But the less expensive Audioquest Cables worked just fine, they grab tight, they insert properly, and don't have heavy-bulky Jacks. The Evergreen Model being the cheapest, and the Chicago Model both possess the same type Jacks and both work perfectly fine with the 4100.
I have been using a 2m AQ Water Cable with the 72V DBS coming from my Denafrips Terminator II DAC, and while the Jacks themselves are fine and fit tight with a solid connection, the DBS network is pretty heavy though, and found I have to support the Cable at the rear of the Reciever with a small block of wood so no undue pressure is on the 4100's Aux in Jacks.
Yes I know, a bit of overkill, a $4500 DAC with a $950 list Cable. I did buy it from Musicdirect, but think I only paid $450 for it.
