You have helped me a lot. Many thanks.
One last question: On the subject of Exterior Antennas, what should be taken into account?
Do you think that this outdoor antenna will be enough to get a good signal ?:
1DB TELEVES CIRCULAR FM ANTENNA
SKU: TEL1201
Price: 28.53 Euros
1dB Circular FM antenna Televes 1201
This Televes Antenna is used to receive FM radio signals. It is a circularly folded dipole antenna, so an omnidirectional radiation pattern is obtained. It has an exceptional shielding to protect the signal from possible interference or noise, which manages to give us quality to the installation and to the signal.
Antenna built in stainless steel and ABS plastic for a long life and great resistance to the elements. Robust and stable mast attachment even in strong gusts of wind, Supported mast diameter: Ø 20 - 50 mm.
DETAILS
1dB omni-directional FM radio antenna (88-108 MHz) with the Televes guarantee
Main characteristics of Televes FM 1201 antenna:
• FM Terrestrial Antenna 88-108MHz G1dB.
• Omnidirectional optimized.
• Zamak clamp.
• Shielded junction box.
• Protection against atmospheric discharges.
• Shields the signal from interference and noise.
• Extends the life of the antenna by increasing the degree of protection of the coupler circuit.
• FM channels.
Technical specifications of Televes FM 1201 antenna:
Working band: FM
Gain: dBi: 1
D / A ratio: dB: 0
Wind loadF: N: 27 @ 130 Km/h
37 @ 150 Km/h
Mast diameter F: mm: 20...50
MORE INFORMATION
EAN: 8424450012017
Pickup: FM
Environment: Exterior
Orientation: Omni-directional
Terrestrial Antenna Gain: Low
Dipole: Passive
LTE 5G Compatible: No
UHF Antenna Power: No
Thank very much
