What is this diode ?
kikook
Member
Hello, I'm searching for a replacement for this diode on a Scott 235S :
I'm sure that the original is dead but not sure for the ideal replacement.
On the Diode I can see : SI (or ST) 22-002. Nothing else.
Can you help me ?
Thanks.
What's in the schematic. Judging from the components around it, I'd suspect a power supply circuit is involved.
This could indicate that you're potentially dealing with a zener of some sort. In this case, you'd have to de-engineer the circuit to determine what it would need to be.
It could also be a blocking diode of some sort, since its tied to a resistor, which makes it look like a retrofit of some sort.
It all depends on how its wired up. What's the problem with the unit?
Cheers,
David
The problem is an outpout transistor, only one (four 2sd313) very VERY hot 5 seconds after power-on.
Everithing else is ok, amp is working, only this diode...
Thanks !
One output is hot??? You have other problems IMO.
Measure across this diode. It ought to be 0.7 volts DC. if shorted, sub a 1N4002 or better.
The diode is dead : no reading.
Ok, so I can use a standard 1N4002 ?
I will try tomorrow morning and see what happen.
The best way to check that diode is to un-solder one leg from the circuit board. If it is good, it will read on an ohmmeter in one direction only (meaning switching the probes around). If it reads in both directions, it is shorted. If you get no reading in either direction, it is open. What I want to know is why do you think that diode is a problem? Is it blowing fuses? Is one channel distorted? Is a protective circuit kicking in?
The amp is working perfectly.
The eletrolytics caps are new. (the problem was here before).
The 4 outpout transistors are new : one was bad on the other channel. On the good channel, the original transistor was also very hot.
All the transistors have been controled and also all the resistors.
The diode have been un-soldier for testing it : no reading in either direction.
Good, to see its fixed. Was that diode part of the power supply or what? Where abouts was it in the amp?
Here is the "monster" :
Inside :
The diode (Changed on the two chanels) :
Very good sounding, I have also a 255s, very good too.
I would use a 1N4007 instead of the 4002. Also check the associated components to the diode if they heated up as well.
Ron
So your diode was open and not regulating the voltage to that side of the circuit. Great you got it working.
I've check the components near the diode (and the others components too), no heat at all, no sign of problems...
Thanks !
Man, I wouldn't wanna stick a quarter in an extension cord over there. :no: I did that here when I was 4 years old. :nono: My mom keeps telling me to this day, you burned two notches in that quarter, I should've kept it! :D
The 1N4007 is the highest breakdown voltage of the series. 1N4002 is easiest to find and works fine in this application. Since the diode is near the bias pot, it probably caused the bias transistor to turn completely off, maxing out the bias. Bias pot typically turn the bias transistor on. The more the transistor is on, the less bias there is.
