x_25
Big Vandies!! Mwahahah...
I am making this thread, not for your impression of how your system sounds, but for numbers of what it can do. So lets see some db levels and graphs. Also of curiosity is at what level you keep it for normal listening.
So my system.
Speakers - JBL CF150's
98db @ 1w @ 1m
15" woofer
6.5" mid
1" tweeter
Frequency Response(-6db) 32hz to 20khz
Receiver - Realistic STA-85
35wpc
THD 0.3%
CDP - Magnavox FD1051 BK-01
TT - Dual 1009 with a Pickering XV-15 400E (I can't find rumble, wow and flutter specs for this. But the wow and flutter are minimal with a 7.5lb platter that does not like to change speed.)
Amazingly, my massive speakers can play really quietly, just berily being audible. The Radio Shack SPL meter I was useing couldn't actually measure it, even at 3 feet so that puts it a less than 50db (this is with the loudness on).
Measuring my average listening level, cam out to be between 60 and 70db (8ft back at my listening spot) I did not realize that I listened to it this quietly.
My receiver needs some help so I put it up to the max volume that I felt it could handle (any higher and the lights start dimming and strange things start happening). At my listening spot I got 104db, which is darn loud. (working backwards from the db level with an spl calculator this means my amp is only putting out 10 to 15wpc before it starts having problems, I need to take a look at it).
Now for some fun things, graphs. I played white noise from a test CD on my system and, using a spectrum analyzer that one of my coworkers wrote, came up with this graph of frequencies at my listening spot, less then +- 3db from 30hz to 10khz (where the mike drops off rapidly, so I cannot measure above that).
and a picture of my set up.
So my system.
98db @ 1w @ 1m
15" woofer
6.5" mid
1" tweeter
35wpc
THD 0.3%
