Is the pre-amp or amp responsible for the volume limit and clipping...or a combination of both?
Trying to figure this out on my system...which I'm currently running the pre-outs from my R-117 receiver to my Crown amp...with the receivers internal amp unplugged. So normally if using the receiver with pre-outs to mains the volume limit is around the 10-11oclock range. So when using it as a pre-amp only and the Crown is set to wide open...is this 10-11 range still the limiting factor..assuming the Crown can take it? Is the 10-11 range on the pre section of the 117 always the limit no matter what its driving..ie..if I crank it to say 12-1 range and the amp has no problem with it am I still overworking the pre section?
I have the Crown input sensitivity set at the 1.4v setting and the clip light never comes on. The only time it did flash is when I had it set at the .7v setting. I never got a clear answer on that setting as I dont know what the 117 output actually is...so I leave it on the 1.4v setting.
So when the clipping lights come on...is it the pre-amp or the amp causing it? Oh..and if it matters this is assuming the same speakers being used and they can take it and more..
I'm not that good at explaining things but here it is anyway.
