have had the Crowns maxed out volume wise with no problem..I just feel safer keeping it backed off a bit for my speakers sake. I have one Crown running my 250's and one for my 240's. On the 240 amp I have it set at 5/8 of max...my reasoning being the 240's are rated at 300 watts and the 250's are 400 watts. The Crowns are 500 watts each.
Generally the lights on amps like this Crown and McIntosh are showing you they are detecting distortion at a predetermine setting like 0.01%, they are not indicating clipping. The Crown most likely has a circuit like the macs Power Guard. When the input signal to the power amp reaches a distortion setting the lights flash and the power amp does not go past that level, even when you turn the volume up, the power amps dial back the output to hold and not go past that distortion setting.
I know your 250 will handle more than that crown will give them and maybe the 240s as well. McIntosh is known to under rate their amps, heres two pairs of JBLs L250 and 250ti driven with two MC501 mono blocks 500wpc, and a MC402 400wpc. You'll also will see my power amp lights flashing witch means the power guard is activated, nothing is clipping though.
