What modern things do you hate/dislike?
Too many containers are now a SQUEEZE bottle. It's bad enough to have ketchup bottles "farting" and spraying the table, now they're putting mayo in squeeze bottles. The best part? It's not made to sit "upside down." So, every use you have to shake the hell out of it to get some mayo to come out.
I told the BOSS: "Don't ever buy this again....please!
I don’t like beer in cans. Just put it in a glass bottle.
They even go so far as to coat the inside of the can, so ot will not affect the flavor of craft beers. I doubt Anheuser-Busch does this with their piss water products.
Devices that need a remote control to operate... I like the old ones, at which you can do some things without the remote control.
The only thing in my house with a remote, other than the TV, is a mini-split HVAC unit. Since the indoor air handler is only for one room, mounting a wired thermostat seems a bit silly. So a remote makes sense.
What other items are you talking about, that now have a remote?
I remove (which isn't easy) the fart part which leaves an open port without the annoying unpredictable spray.
GoPro cameras. I've hated my GoPro 10 since day one (and the 5 I had before that). It has a crappy user interface, battery life is ridiculously short, it overheats (often), it requires proprietary GoPro software to access the videos, and the microSD card frequently gets corrupted, even when using the highest quality/speed MicroSD. I had a really critical video I from Europe that I wanted to access, it would play on the camera itself, but was invisible when you tried to load it anywhere else. Tons of research says the file is corrupted. I don't know how GoPros are so popular, mine has been jhust glitchy in every way in the years I've owned it.
I just ordered a DJI Action 6 to replace it -- the DJI camera is better in virtually every way than the GoPro and doesn't require glitchy proprietary software to operate and access files. I will be thrilled to be rid of the GoPro. The only downside of the DJI is it isn't integrated to things like track apps that allow you to start the video from the app (that is a feature I will miss), but it can be worked around.
My GoPro has been trouble free. The only things I hate about it is that it takes a large capacity memory card to get any good video length.
The other thing is, filming motorcycle rides became not fun anymore. And that is all that I used it for.
I did not have any problems viewing the video on my Mac computer. Just pull the memory card from the camera and insert into usb adapter and import into photos or any video editing software.
It works fine on a motorcycle or skiing because there is air flow, but it doesn’t work (for long) in a track or race car where there is no air flow, or even recording a music video indoors (where it is cool but there is no air flow). It shuts down after a few minutes. You can’t use a fan because it will be very loud on indoor recording (we tried). We set ours to “tripod mode”, which is supposed to reduce heat shutdowns, but that limits frame rate annd other options, and it still overheats.
You’re right, you can pull the files off by removing the microSD. I think in the old days you could just plug the USB in, but they disabled that IIRC. Removing the SD is certainly workable.
The files being corrupted is VERY common if you search for it. It would play on the camera but no way to see or recover the file on the SD.
There is a trick supposedly to force the GoPro to repair the file, which is to start recording a new video and pull the battery while it’s still recording (this triggers the GoPro to automatically repair the new video when power is restored). So then you pull the SD, rename the file you want to recover to the new video's name, then plug the SD back in and insert the battery. This is supposed to trick it to repair the old file, but it doesn’t work. They could have a “recover all” option to help resolve, but they don’t. Only solution to make it functional again is to reformat the SD, losing all data.
I was going to try to send the HDMI video output from the GoPro into a computer capture card, but it costs something like $70 to get the GoPro adapter that allows you to output HDMI. I was about to buy it (kind of throwing away money because I already knew I was going to get rid of GoPro), that’s how much I wanted to get the video, but the video stopped playing even on the camera.
Picture quality is good, even sound quality for acoustic music, but it’s just been a nightmare to deal with the entire time.
I just saw that GoPro is being sold for $285 million -- one fortieth (1/40th :eek:) its $11.3 billion market cap in 2014. I hadn't kept track of it's stock price at all, but apparently the market has long felt what I've felt from a user experience. Hopefully the new owner will make the GoPro cameras and ecosystem better.
I just received the DJI Action 6 camera replacing my GoPro 10, but haven't used it yet. The battery life alone makes it worth it, but almost all reviews shows it beating the GoPro in most categories. The DJI Action 6 has a square sensor, so it takes a larger video and then you can pick where you want to frame the 16:9 later (or use the whole square video or choose a different aspect ratio). A professional photographer friend, who switched fro GoPro to DJI for pretty much the same reasons, says he gets 3 hours+ out of his DJI action 5. We couldn't make it through an autocross (a series of very short runs) a couple weeks ago on one battery with the GoPro 10, and the camera was running hot.
Hopefully GoPro comes out stronger from the buyout -- it's always good to have competition.
My %&%$#!! over complicated flashlight!?
Sure it is the brightest flashlight I have ever owned (LED) and it is rechargeable. It even can vary the focus the beam from a fairly small spot to a very broad one.
So instead of just a freakin' on/off switch, it has a rubber covered membrane button that "switches" between modes (like a dimmer setting or different flashes) and you need to cycle through several before getting to the desired "off". It must have some sort of processor because it shows charge status and -here's the REALLY annoying part- the stupid thing will turn itself off!!? Zero provocation..just shuts off. We lost power last night and the stupid thing shut off while it was just sitting on the counter. Did your old flashlight with that sliding switch ever turn off before you wanted? NO!
Waaayyy too complicated.
I have a couple of inexpensive backups that work like that, but they don't shut down unless they are in the highest setting.
I liked how the Streamlight single rear button worked, but it would not take higher voltages of fresh rechargeables according to the manual.
Replaced it with this one where the rear button trigger stays in the last mode and forward button changes mode. Still prefer the streamlight, but it's been in service for a while. Light and comfortable with summer shorts, so I always have it.
I was going to post this also!
I have a bunch of LED work lights for the garage, also head lamps on a strap (those are a game changer for working on the car). The lights themselves are amazing in terms of brightness and (to a slightly lesser extent) how long they run, but user interfaces are super annoying. I haven't figured out how any of them work because they are all different, and I keep bouncing between them depending on what light I need. I just mash buttons until I finally stumble on what works. Some have a color temperature setting (cool/warm) in addition to brightness, then there are also flashing modes on some lights. It is really annoying to click through them -- usually you can't know you are already on the brightest setting until you click past it -- so then you need to take another "lap" around the modes..
Let's not forget the battery charging indicators on those lights that also vary wildly. The "no brainer" charging indicator approach would be to have a simple red (battery low) / yellow (partially charged) / green (fully charged) indicator, but that is NEVER the case. On some, a green LED mean it's charged, on others green means it's charging, and sometimes the status LED being off means it's charged -- sometimes red means it's being charged, on others it means it's fully charged, and sometimes red means it's discharged. There oughta be a law demanding uniformity on user interfaces! :)
Another Modern thing I hate: It seems like an increasing number of websites try to force you log in by sending a code to your phone or email instead of using a password. I haven't really thought through this too much -- so maybe there's something I'm missing -- but it seems a lot less secure. If somebody has access to your phone, for example, they will get the code texts and emails and log in.
Stop making sense... :)
Domestic appliances that use electricity and water, that can be turned on with wi-fi.
It's an unnecessary expense, as no one in their right mind, given the build quality of them now, would have them working when they were out of the house.
We've both a dishwasher and a tumble dryer that have wi-fi and didn't want it, but we had no choice.
They can also be turned off or given hours of operation.
I've read that some appliances and cars *require* internet access and a subscription from the buying consumer to 'unlock' certain features.
So, you're paying for an appliance with features you cannot use unless you comply.
