Quite a few years ago I realized that if I wanted to listen to audio in my little listening room I would have to switch out the tube power amp for something that produces less heat. I went on a little quest to try to find a SS power amp that came as close to the sound of my tube amp as I could manage. I went through several of the amps usually cited, a number of Quads etc. and finally ended up with a McIntosh MC-250 as the closest I have found. Maybe it's the transformer outputs, but mine sings with the same sweetness as the EL-84s.
What amps have you tried that worked for you? I know other folks must have the same issues to work with....
