The question should be which tube amp sounds more like SS. I'd go for a MC2301. And I bet if you put a pair 2301 up against MC2300 the 2301's would win at any power level. That's a scary thought.
I am in effect running a tube/SS hybrid situation at the moment except in two boxes rather than one. I tried running a couple of Class A SS amps as well as the Quads (405, 502f and 606) and while they were all very good they kinda missed the point. It isn't fat mid-range I'm looking for, either. My tube set-up is balanced like a good SS would be in that sense. It really comes down to handling of the harmonics resulting from the mid-to-upper treble frequencies that is the kicker. That is where the MC-250 somehow manages to get where I want to be with my sources, pre and speakers. It is a subtle thing, but for my ears an important one.Which SS amps sound like Tubes? Well...
It depends on what qualities of a tube amp you are looking for. If its that warm sound (with respect to a slightly elevated mid range) we can voice a SS preamp or power amp to do that. If you want the low damping factor effects of a tube power amp, That is a different matter. Some speakers may sound noticably better with low damping factors, With most speakers however it's not an issue. If you want the 3-D effect of a single ended tube amp, We can do the same thing with a single ended SS preamp or power amp, But I think few do.
Also SS power amps maintain a very flat frequency response over a wide impedance, Not so with tube power amps, that's why the speakers impedance should be matched with the proper transformer tap. So many speakers will sound different with tube amps and SS, irregardless of how close everything else is. There may be exceptions. But generally these factors may help explain why tube amps are still in demand.
If the audio section of a source is tubed, or a tube/SS hybrid, they can produce the effects a tube preamp produces as well, depending on their design.
Well the "source" sounds like a minuscule amount of voltage you'll never hear through your speakers. So I'll say "me" - I want it so that I can actually hear sound in the room.
I'd agree the OP wants to be looking at some quality Class A gear or perhaps Mac stuff. I've compared my 754 (SS) to my 275 (Tube)and although the 754 comes pretty close, it loses some smoothness and liquidity to the highs. They most definitely and absolutely do not sound the same.
jblnut
That wasn't the point of the challenge. Bob claimed that he could tweak his amp to sound identical to any other (be it tube or solid state). That very claim suggests the premise that different amps do in fact sound inherently different.
Stereophile just happened to select a tube amp (Conrad-Johnson Premier Four), hoping the difference was vast enough to guarantee Bob's failure.
JBLnut come on you know damn well what I mean. The source as in what the amps see's prior to amplification. Anything differences from what the line source going into the amp to what comes out as output of the amp, is distortion, of one type or another.
So you're in the camp that all SS amps sound the same?
Early David Hafler ss gear was well regarded back in the day. Given his immense expertise in tube amplifiers, designing and building t-formers for tubes, he should have been able to voice a decent SS amp.
I have a small D.Hafler 120w amp/D.H. pre that I bought new in the early 80's, and I still like it. I have them paired with some Bozak B302a's, and they play nicely together.
Plinius is another good SS name that gets that "tube-like" nod from the afficiandos.
One reason is their transfer curves are similar as observed by Nelson Pass.People always mention FET amps as closely related to tube amps soundwise.
Why unconditionally? Is there a such thing in audio (if not world)?
I've read this here which isn't terribly far away.I've never seen that said.
