HiFiAaron
Member
I have a pair of Renaissance 80's and was uncertain weather to keep them or not. But after listening to them many times the hunt for a better amplifier begins.
I'm currently using a Samson s1000 amp and a Yamaha RX-V663 receiver as a preamp to power them. I am pretty satisfied with the the Yamaha functioning as my preamp for now but may be looking into something different in the future. The speakers sound great with this setup but they could sound much better with a better amp. The amp is pretty basic and not really matched well for the speakers as they revile all imperfections.
Ive been looking at amps but I am not really sure where to go. I would like it to have low distortion and preferably a wider frequency range than 20hz-20khz as the Infinity claims the Renaissance 80's go up to 45khz! I don't know how much you can hear that difference but i would sure like to. Also these are 4ohm speakers known to drop as low as 3.3ohm and are considered amp killers in some situations so I need something with a good supply of power. the minimum power handling for the speakers is 75watt and the max is 300watt each. I would like it to be $1000 US or less for the amp. I like vintage gear so age isn't an issue.
What are your amp suggestions? (cheaper the better. I'm not cheap but I'm also not rich)
How much would I benefit from a different preamp?
Any help is much appreciated.
? I am curious if I would be able to hear another 25khz on the top if I had it. It does sound quite clear and what you say makes sense. I guess it just makes me wonder when i see these amps rated at .005 - .06 THD it makes me wonder if I would hear the difference. I want to try hooking up my cd player to the amp and use the gain controls to hear the sound without the Yamaha but I am concerned, as i only use about a quarter of the amps power as is and the speakers get very loud, that it may be too loud for the speaker even all the way down. The gain controls have notches rather than a smooth adjustment so i don't know what the jump from all the way down to one notch up will be. I will have to play with it a little. As far as preamps are concerned what would you all advise I don't think my Yamaha is doing a bad job but I would not be opposed to putting something with more potential there. do they have preamps that do digital conversion or would I have to switch my digital stuff to analog and use a source switcher? Sorry if these are noobish questions I just have been satisfied with the gear at hand for some time until these ren 80s came along now I have an itch all the sudden.
