What turntable is this?
Thorens
Prolly a TD 145 because the front area below the platter is black.
However, those usually came with a horizontal metal strip across the front wood panel, thusly:
Love the Decca record brush.
I did a listening session with platter mats on a TD-160 Super. The Thorens mat did not get a second listen. The Marcof Glasmat was crispy sounding. The Platter Matter, heavy rubber-like sounded bass heavy and thick. The Herbies Way Excellent mat sounded clean, clear and smooth top to bottom without emphasis the way the heavy Platter Matter blurred the sound and the Marcof accentuate the highs.
Recommend you investigate mats the 160 will let you hear them and you can do better than the Thorens mat.
Nice-looking TD160 and even the armboard looks properly centered. Stock appearing power and RCAs, a little elbow grease on the cover to buff out some of those scratches will make a big difference. The rest of the table appears to be nicely cared for. You can check the "bounce" using the guides over on the Analog Dept. along with a few other adjustments but on balance, these are pretty straightforward machines. The bearing will need to be cleaned and freshly lubed with some 3in1 electric motor oil, at least that's what I've been using in mine.
https://www.lowes.com/pd/3-IN-ONE-3-in-One-3-oz-Lubricant/1210103
What cartridge is that on there? It has the original TP-16 tone arm, which is no slouch, and you'll get more information on that on Analog Dept. as well. The only caveat I've heard about it is that it doesn't really do so well with highly compliant cartridges, so that's something to consider should you wish to replace the one on there. By the way, can you see which cartridge that is and tell us?
Thanks for the better pictures, FM, and enjoy your new table!
Frankie, this site has all the information you might ever need on cartridges:
https://www.vinylengine.com/
When you get there, select the "Database" tab and it will take you to another page where you can select either turntables, tonearms, or cartridges. Select cartridges and then find your model.
You really need to provide more information as we don't know which model you have. There are many V15 models, for instance, and the Supertrack just denotes a broad designation for some of the models that utilize a particular stylus as far as I'm aware, but Shure is not my forte. Somewhere on your cartridge you will find a model number and that is what we need to be able to assist you further. Conversely, you can just go to the site provided above and find it for yourself.
PS - A lot, not all, of the Shure carts are listed as tracking between .75-1.25gr. Still be better to know exactly which one you have.....
