AZBiker
Hello,
I'm working on a 2330b. I found that one of the wires that connects to the P700 board through a connector, broke at the connector. It's a two-conductor wire that goes to the Power Amp In RCA jacks on the back. It appears to be simple 2-conductor wire but it could also be shielded; it's difficult to tell because there's a piece of heat shrink where they stripped the wire.
The exposed part of the wire is solid because they used wire-wrap to make the connection. My question is, does this need to be a twisted pair or a shielded single conductor due to it being in low-level audio path? It's the same type of wire that goes to many of the low-level inputs on the back of the unit. Thanks in advance!
