cpt_paranoia
Addicted Member
Marshall Leach wrote this and you need to keep it in mind when considering crossover types:
I'd also point out component tolerances as an overlooked issue when designing crossover filters. All very well designing a super-duper crossover filter that will give great results with perfect components, but real components like capacitors tend to have large tolerances. Which means your filter may end up having response lumps in unexpected places, and your L-R filter may look more like a Butterworth. Since, as the OP noted, the circuit configuration is the same, the filter type is only defined by the component values. If those values aren't the ones you designed, your filter isn't the one you designed.
